Forget Bhp What About Torque
57 replies to this topic
#16 Rusty1182
Rusty1182
  • 389 posts
  • Local Club: Mini Allsorts
Posted 22 August 2017 - 03:29 PM
ok sounds good.
say my car had a metro cam. would it be worth replacing. do they get worn out.
to find out what i have. i need to strip it down so i might as well replace it.
#17 neal
neal
  • 318 posts
Posted 22 August 2017 - 03:33 PM
Yes, you might as well but it all depends on your budget
#18 Rusty1182
Rusty1182
  • 389 posts
Posted 22 August 2017 - 03:46 PM
Ok and with the Diff is there a way to find out what i have now without pulling it apart.
#19 Rusty1182
Rusty1182
  • 389 posts
Posted 22 August 2017 - 03:52 PM
Also with the diff is it worth getting a LSD for the road
#20 racingbob
racingbob
  • 3,061 posts
Posted 22 August 2017 - 04:10 PM
You don't need Lsd. I think the only way is count the teeth apart from driving it. And moly diff pin should be fine is in mine. However go for 4 pin if you want
#21 Rusty1182
Rusty1182
  • 389 posts
Posted 22 August 2017 - 04:55 PM
OK so as far as i can make out the engine code is   12HC01AA 101099
Does this mean much to anyone?
Ant
#22 neal
neal
  • 318 posts
Posted 22 August 2017 - 05:16 PM
The only real way of finding out what's inside the engine is by stripping it, these engines in original form are getting scarce but then again you might be lucky and have a standard untouched engine.
If you do a bit of digging across the internet 'Classic mini engine number' etc. you might come across a site that gives you the full spec of your engine.
Hope this helps
#23 panky
panky
  • 1,790 posts
Posted 22 August 2017 - 05:18 PM
Standard 1275 Metro originally
http://www.guess-wor...Tech/engine.htm
#24 neal
neal
  • 318 posts
Posted 22 August 2017 - 05:19 PM
Try this at Guessworks,
Haha, beat me to it,lol
Edited by neal, 22 August 2017 - 05:19 PM.
#25 panky
panky
  • 1,790 posts
Posted 22 August 2017 - 05:30 PM
Gotta be quick round here ;D
#26 nicklouse
  • 18,574 posts
Posted 22 August 2017 - 06:06 PM
I think I'd go with one of these cams with 1.5 roller rockers and a 3.44 diff.
nope you dont want 1:1.5 rockers
#27 Rusty1182
Rusty1182
  • 389 posts
Posted 22 August 2017 - 06:07 PM
any reason ?
#28 nicklouse
  • 18,574 posts
Posted 22 August 2017 - 06:12 PM
Ant
so you will be going for a full rebuild then? forget what you have and pick a new short motor and head to suit.
so what is your budget for the power unit less gearbox?
#29 Rusty1182
Rusty1182
  • 389 posts
Posted 22 August 2017 - 06:19 PM
It's not so much of a budget issue.. obviously the cheaper the better but needs to be done correctly. and not cut corners.
and it's more about getting the right spec   if a good torquey engine is going to cost 2k then that's what i will spend
what i don't want to do is spend money on modifications that won't make much difference or are just silly money.
i want to keep NA no turbo   and happy at 1275 for now.
#30 neal
neal
  • 318 posts
Posted 22 August 2017 - 06:41 PM
Nick,.......I was just stating my preference and not telling him.
You however....
