Gearbox- Damage To 1St Gear?
9 replies to this topic
#1 tb205gti
tb205gti
  • 186 posts
Posted 20 August 2017 - 06:47 PM
I'm stripping a "new" 1275 engine that I bought - so far it seems OK, there are some things I need to fix - however I have those covered.
But now I've come to the gearbox. And there is a damage to two teeth in the 1st gear cog. (2 arrows to the right)
..Now my questions is, should I rebuild the gearbox replacing the damaged wheel, or will it be OK to use it as it is?
Also; What is going on at the arrows to the left? Is that part of the synchros - or what function does this one have? It is quite beaten up :/
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 20 August 2017 - 07:01 PM
Throw them away, you wouldn't want to take it out again as a result of failure, those dog teeth are well chewed up on second
#3 imack
imack
  • 2,381 posts
Posted 20 August 2017 - 07:36 PM
Probably got worn/damaged teeth in the syncro hub too.
#4 Swift_General
Swift_General
  • 871 posts
Posted 20 August 2017 - 09:24 PM
And check the layshaft given the damage on first gear, then baulk rings etc (i.e. it needs to be revuild). As above there is damage on the second gear dog teeth, the gearbox would have been crunching on second gear (where boxes commonly start to crunch first due to frequent changes into second).
#5 Spider
  • 15,843 posts
Posted 21 August 2017 - 08:00 AM
First gear has had a beating and on Second Gear, while the teeth look OK, the dogs have had it. It will always jump out of 2nd.
#6 mini13
mini13
  • 3,811 posts
Posted 21 August 2017 - 04:58 PM
Looks like 2nd gear synchro is shot and taken out the teeth on the sycro hub and gear, so that will at the least be very crunchy,
Not sure what's happened to 1st, but it doesn't look good, forensic object gone through the teeth perhaps.
#7 tb205gti
tb205gti
  • 186 posts
Posted 22 August 2017 - 06:30 PM
It's a new parts job I can hear. Now where do I buy the newparts? I have not been able to find the dogs or synchro parts anywhere. Baulk rings yes - but not the others.
#8 tb205gti
tb205gti
  • 186 posts
Posted 22 August 2017 - 06:32 PM
...Another queston. The gearbox in my 998 A is perfectly sound - can I use that for the 1275A+ engine?
#9 Spider
  • 15,843 posts
Posted 22 August 2017 - 08:48 PM
The dogs are one piece with 2nd gear, so put another way, look for a new second gear.
It appears you have a  'single line' gear set, 2nd Gear should have 26 teeth (for you to check) - P/N DAM4932
http://www.somerford...oducts_id=12706
Synchro hubs are usually OK, but best to check. P/N DAM7499
http://www.somerford...oducts_id=12752
<EDIT: You should be able to fit your 998 gearbox to the 1275 engine OK, however, you'll need the 1275 Primary Gear. Also, decide if you want to use the Crankcase Breather on the Transfer housing so that while it's all in bits, you can drill and tap the holes for this. Personally, this is the set up I prefer. You'll need to use the transfer housing from the 998 as it will have the matched bearing ring for the outrigger bearing. >
Edited by Moke Spider, 22 August 2017 - 08:51 PM.
#10 cian
cian
  • 869 posts
Posted 23 August 2017 - 03:05 AM
I may have some good used gears available, pm me what you need and I will have a look
