Extra Spacers On Sports Pack Mini?
9 replies to this topic
#1 Cooper99
Cooper99
  • 14 posts
Posted 18 August 2017 - 05:44 PM
My MPi which is originally equipped with sports pack needs spacers both at the front and rear to improve the looks. The rear wheels have the 8 mm sports pack spacer and there's Hi-Los in the rear. When measuring there is 25 mm in the front and 23 mm in the rear until the wheels sticks out of the wheel arches.
My question is if it is possible to add such spacers (and change to longer studs) without having e.g. steering problems or other?
#2 brivinci
brivinci
  • 1,177 posts
Posted 18 August 2017 - 06:35 PM
The short answer is NO! On the rear, sky's the limits I guess but the front will throw the suspensions geometry completely off. I believe it is all to do with the king pin inclination. Look it up for more info on that. The only way to counter that is to put on wider wheels with the correct inner and outer offset.
Ages ago, I went and did what you are talking about for my SPi on 12" with W&P arches. They were wider like Sportpack arches and the stock Rover 12's seemed too far in for me. I added .75" spacers on all corners and although the look was right, the steering was boarding on diabolical. It was extremely heavy and over bumps, it would dart this way and that. I would NOT recommend doing this for looks alone.
#3 mab01uk
mab01uk
  • 12,413 posts
Posted 18 August 2017 - 08:03 PM
You would be better to go for 7 x 13 wheels with suitable offset to fill the arches but even this will increase bump steer and spoil the Minis handling.....however for some 'looks' are more important.
Fitting wider spacers just for 'looks' is never really a good idea.
Edited by mab01uk, 18 August 2017 - 08:04 PM.
#4 Cooper99
Cooper99
  • 14 posts
Posted 19 August 2017 - 06:50 AM
Thanks for your answers. The handling of the car is to some extent already spoilt by the sports pack wheels; it's a big difference to a Mini with 10" or 12" wheels.
But since my car have the sports pack I want to try to "maximise the looks" without having to pay too much in negative handling effects.
I like the sports pack wheels, but have been thinking of getting 7x13 Revolution (with rivets). The sports pack wheels offset is 21 and the Revolution is 13. By using a calculator I got the following results. What do you think about the inner clearence will be 5 mm less? And will the handling be much worse than it already is with the sports pack wheels?
#5 eric.sen
eric.sen
  • 113 posts
Posted 19 August 2017 - 07:43 AM
I asked the same questin last month,
I put yesterday the Minispares CW17 kit 3/4 spacers +78mm studs
Only on the rear
And didn't see any change on handling
#6 eric.sen
eric.sen
  • 113 posts
Posted 19 August 2017 - 07:52 AM
Edited by eric.sen, 19 August 2017 - 07:53 AM.
#7 eric.sen
eric.sen
  • 113 posts
Posted 19 August 2017 - 07:58 AM
Just perfect with 19mm (3/4")  spacers for my eyes,
the front doesn't need any thing.
#8 Cooper99
Cooper99
  • 14 posts
Posted 19 August 2017 - 06:46 PM
Yes it looks nice on your car.
So, I have the choice of getting 19mm (3/4") spacers and new studs for the rear, but leaving the front as it is, or change wheels to 7x13 with suitable offset. You Brivinci and mab01uk indicated that the offset must/should be the same as the current wheels. Anyone's got an idea if the differences in offset between my current wheels and Revolution 7x13 (see the results of the calculation 4 posts up) will give me any problems (major, minor?)?
#9 Cooper99
Cooper99
  • 14 posts
Posted 27 August 2017 - 03:49 PM
Eric.sen, as I understand you have both the 8 mm spacer (sports pack) AND the 19 mm spacer, with 78 mm bolts? Is that correct?
#10 eric.sen
eric.sen
  • 113 posts
Posted 28 August 2017 - 08:36 AM
No
I only have the new 19mm spacers and 78mm studs in the kit CW17
The genuine 8mm spacers are now on a paper tray !!
