Me too, been using Valvemaster Plus the whole time as it was reasonably priced although I don't do so many miles so it is probably not a big deal for me
Lead Replacement Additive - Which One Now Castrol Valvemaster Is No More?
#16
Posted 18 August 2017 - 07:39 PM
#17
Posted 18 August 2017 - 07:57 PM
I put a piece of old lead from a pipe ect in the bottom of my old mk1 S and she still runs a treat now today
#18
Posted 18 August 2017 - 08:43 PM
I've had a quick look on the net and can't find the answer but no doubt you users will know,what's in It? as in what is the active ingredient
Shooter
The Castrol is Phosphorous based.
The Millers is Manganese based.
http://www.fbhvc.co....el-information/
#19
Posted 19 August 2017 - 05:31 AM
I haven't had the need to use any additives so I can't offer any experienced words, however, there is a couple of additives I have found in recent years that do appear promissing;-
http://www.hi-flow.com/HP016aOS.html
#20
Posted 19 August 2017 - 09:01 AM
Shooter
Also the original FBHVC/MIRA testing of these fuel additives was carried out using A-series engines
#21
Posted 19 August 2017 - 11:58 AM
The valve seat inserts I use are those from minispares and are 31.75mm in diameter. You can physically seat a 31mm exhaust valve however too much heat is dumped into the casting and failure often occurs.
Ac
Edited by ACDodd, 19 August 2017 - 12:08 PM.
#22
Posted 19 August 2017 - 03:28 PM
http://www.tetraboost.com/
I looked at the tetraboost if it does indeed contain tetraethyl lead, that's a bit of a no no with road going vehicles, but there again I plan to boost octane ( not on the mini engine ) with paint thinners which no doubt isn't too correct either.
Shooter
#23
Posted 19 August 2017 - 07:17 PM
Doesnt work. You ll find next to no lead in the fuel unless you go through 1 tank a year orso
And far more caricinogenic if things like toluene are used..I looked at the tetraboost if it does indeed contain tetraethyl lead, that's a bit of a no no with road going vehicles, but there again I plan to boost octane ( not on the mini engine ) with paint thinners which no doubt isn't too correct either.I haven't had the need to use any additives so I can't offer any experienced words, however, there is a couple of additives I have found in recent years that do appear promissing;-
Shooter
#24
Posted 19 August 2017 - 07:22 PM
Might have to keep the empty bottle and see if I can get the millers stuff in to it.
#25
Posted 19 August 2017 - 09:43 PM
Doesnt work. You ll find next to no lead in the fuel unless you go through 1 tank a year orsoAnd far more caricinogenic if things like toluene are used..I looked at the tetraboost if it does indeed contain tetraethyl lead, that's a bit of a no no with road going vehicles, but there again I plan to boost octane ( not on the mini engine ) with paint thinners which no doubt isn't too correct either.I haven't had the need to use any additives so I can't offer any experienced words, however, there is a couple of additives I have found in recent years that do appear promissing;-
Shooter
Yeah but I smoke so the odds are already stacked:) plus diesel is worse
Shooter
#26
Posted 24 August 2017 - 06:58 PM
Actually there is little evidence that toluene (methyl benzene) is carcinogenic. However its cousin benzene definitely is. Benzene is in much higher concentrations in 98 petrol, so if you use that, avoid breathing in the fumes whilst filling up.
Personally, I wouldn't use anything that contains tetra-ethyl lead.
Edit: I use Morris Lubricants zero lead 2000 in my Moke. It's potassium based
Edited by govig, 24 August 2017 - 10:24 PM.
#27
Posted 24 August 2017 - 08:38 PM
+1 for being careful with TEL, this is pretty deadly stuff. But very effective.
The maximum permitted level of benzene in UK petrol is 1%, for all grades.
#28
Posted 25 August 2017 - 01:14 AM
Shooter
Shooter
Bah - puts hairs on yr Chest
Fair enough if anyone in particular doesn't want to use TEL these days, but given that zillions of cars all around the world burnt it for around 50 years and now very very little burns TEL, the small amount a few older car enthusiasts are going to burn will, i feel, make little difference. Let's face it, 'life' will drive us all mad (if marriage doesn't first) and give us all cancer.
And yes, Diesel is WAY worse than TEL,,,,
I did look in to using Benzine (basically Paint Thinners) a little while ago as an Octane Booster, I'm quite sure that's what they use in the Petrol we have here in fact (that's how I steered on to it), but haven't as yet tried it.
In our Major Cities here, getting true higher octane fuels is usually no issue, but once you leave them - as I so often do - it can be a real headache. Further compounded to this is in some of our regional areas, where the 'Locals" (Abos) are, they can't afford or obtain Alcohol (to drink), so the often steal petrol to get 'off' on sniffing the fumes. To 'get around' this in these areas ,they sell a 'synthetic' (pathetic?) fuel called 'Opel'. Its Octane I'm sure varies from 120 to about 50. So, it's for these reasons that I went looking,,,,,
#29
Posted 25 August 2017 - 07:10 AM
#30
Posted 25 August 2017 - 01:19 PM
I don't know what the Castrol shelf life is but the Millers is 2 years from the date on the bottle, I suspect it'll be similar?
