Engine Rebuild Gasket Sealant Recommendations
17 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 11 August 2017 - 05:57 PM
Is there a specific type that would cover all areas or is it best to use difference sealants for different parts or just use an rtv sealant?
#2 nicklouse
  • 18,600 posts
Posted 11 August 2017 - 07:09 PM
Hylomar Blue
#3 Shooter63
Shooter63
  • 1,037 posts
Posted 11 August 2017 - 07:55 PM
Yamabond is about the best there has ever been, the problem used to be getting hold of it, its silver as well so you engine doesn't look pikie either
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 11 August 2017 - 08:20 PM
I use they grey version of this http://www.halfords....catalogId=10151 I've found it very good for both water and oil gasket applications.
#5 minimans
minimans
  • 411 posts
Posted 11 August 2017 - 08:27 PM
Permatex gasket sealant on the paper gaskets. I used to use Wellseal but havn't been able to find it in the USA.
#6 Spider
  • 14,889 posts
Posted 11 August 2017 - 08:54 PM
I too use Permatex on just about all gaskets and RTV on the Thermostat, Water Pump & Heater Take Off.
I don't use any on the Rocker Cover.
#7 RooBoonix
RooBoonix
  • 1,225 posts
Posted 11 August 2017 - 09:15 PM
Permatex Aviation Form-A-Gasket.
Excellent stuff, yet the thermostat gaskets still leak so they need RTV lol
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 August 2017 - 09:48 PM
Hylomar Blue
Can it be used on rubber (like halfmoon seal)?
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 August 2017 - 09:49 PM
Which type of permatex?
#10 nicklouse
  • 18,600 posts
Posted 11 August 2017 - 10:06 PM
Hylomar Blue
good question. i dont put anything on the Halfmoon.
#11 Spider
  • 14,889 posts
Posted 11 August 2017 - 10:09 PM
Sorry mate. No. 3.
Permatex was bought out a few years back by Loctite, it's sold in some parts under that name too.
https://www.permatex...sealant-liquid/
#12 minimans
minimans
  • 411 posts
Posted 11 August 2017 - 11:35 PM
Wellseal and permatex #3 are both aviation sealants not that means that there better just they are good enough for airplane engine work there good enough for me!  Wellseal was originally formulated by Rolls-Royce and is excellent stuff and it smells really good too. I never use RTV unless the mating surfaces are really bad and can't be refaced for some reason. I've seen a lot of engines over the years assembled/awash in RTV and it gets everywhere you don't want it! I worked on a vintage McLaren with an external screen filter fitted and it was plugged so badly that it starved the bearings at full chat and destroyed a motor............Hateful stuff.........
#13 nicklouse
  • 18,600 posts
Posted 11 August 2017 - 11:38 PM
Hylomar was also developed by Rolls-Royce as it proudly says on the tube ( or made under licence from R-R)
#14 Spider
  • 14,889 posts
Posted 12 August 2017 - 01:03 AM
RTV, like any sealant, should be used in moderation!
RTV is THE 'Gasket' for 99% of the late model Mini Gearbox Diff Caps - they are fitted up with RTV and no paper or anything else;-
http://www.theminifo...kets-important/
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 August 2017 - 08:37 AM
In defence of RTV its not the sealant that's the problem it the lack of understanding of how to apply it. I use RTV but use it very, very sparingly and have never had a problem with excess getting into oilways etc. I know there are plenty of "mechanics" out there who plaster it on thinking more is better, they deserve all they get. Its all down to what you've been taught and how you apply that (no pun intended).
