Mini Van Battery Location
4 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,265 posts
Posted 06 August 2017 - 10:17 AM
where does the battery go? Is it infront of the load panel, or right by the drivers seat?
I cant work it out, there is a space it could go, but no mountings, and also the battery is too big to go threw the hole, but if you put it by the drivers seat, it seems a bit dangerous.
thanks
#2 sledgehammer
sledgehammer
  • 3,108 posts
Posted 06 August 2017 - 10:39 AM
http://i1029.photobu...zps86003268.jpg
usually behind drivers seat in a tray - always seemed a bit daft if driver was a smoker & battery was a bit gassy
usually a good rust spot as acid fumes used to rot the floor on some vans & pickups
(not my mini van by the way)
spare tyre the other side
some vans had the spare wheel well in the rear floor along with the battery (different floor pan - probably like some estates)
can't find pic of it thou
Edited by sledgehammer, 06 August 2017 - 10:46 AM.
#3 Avtovaz
Avtovaz
  • 1,265 posts
Posted 06 August 2017 - 10:55 AM
right ok, i can get it mounted then, maybe it should be a slightly smaller battery than the saloon ones as its right by the seat!
#4 sledgehammer
sledgehammer
  • 3,108 posts
Posted 06 August 2017 - 01:23 PM
http://www.widman.bi...ten_battery.jpg
sorry I can only seem to find really rough mini pickup / van pic's
#5 Avtovaz
Avtovaz
  • 1,265 posts
Posted 06 August 2017 - 07:01 PM
thanks, i had a look about on ebay, and there is some batteries that are narrower but taller, ill measure up and see if i can get one of those in, the standard type is just too big.
Edited by Avtovaz, 06 August 2017 - 07:02 PM.
