I've just received my new MED ST1 ultralight Verto fully assembled ( clutch/flywheel ) just need guidance on fitting as it's my first time .
Is it just a case of offering up to crank and fitting on lock tab and torque bolt and fit the thrust sleeve ?
just to add it's a 1275 cooper engine which has been rebuilt and ready for new clutch to go straight on .
You will need to sort the end of the crank properly for sure.
You also need a C washer and backing washer for the back of the flywheel, which holds the primary gear in place.
Another problem its looks like you will have is the primary gear end float, as you have not got the C washer and backing plate.
Who put it together?
The end float on the primary gear is important and needs to be set ideally before the engine goes on the gearbox, its not as easy afterwards, if it had been built correctly the C washer and backing washer should be there.
Have you a haynes manual? that will help.
You don't have to lap the flywheel on, but in persuit of perfection it is advisable, use a fine grinding paste, clean it off completely and then wash it with brake cleaner so its spotless.
But first that crank tail needs carefully dressing with a fine file and you need the slotted washer for the end to make sure it fits correctly.
You should also be aware that the flywheel and slotted washer only fit one way as the slots are offset from the centre.
The end float on the primary gear is a subject on its own, there will be a topic on here some where. Don't just shove the washers on and assume it will be OK.
Take your time and get it right or it could be a disaster.
