Maestro 1275 Engine
14 replies to this topic
#1 Rusty1182
Rusty1182
  • 389 posts
  • Local Club: Mini Allsorts
Posted 02 August 2017 - 05:37 PM
Hello All
I'm Collecting my new mini on Friday and it has a 1275 Maestro engine in it.
Are these any different from the mini 1275 engines?
I know they are both A series but is the compression etc the same?
also, it still has the Maestro Inlet Manifold.   should I change this for a normal aftermarket one?
Ant
#2 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 02 August 2017 - 05:57 PM
Hi Ant,
From memory, the Maestro was front wheel drive and had an "end-on" VW gearbox and was an A+ engine, so I believe the block and crank would have been different (akin to the rear-wheel drive Morris Marina/Ital/Sprite/Midget/Moggy Minor etc.).
I'm not sure this block would fit a Mini transverse gearbox without loads of modifications. With regard to similarities to the Mini engnie, I believe the Maestro was similar with high compression pistons, but with electronic ignition and an electronic automatic choke.
Cheers, Steve.
#3 Tommyboy12
Tommyboy12
  • 2,253 posts
The block is technically the same but it won't have the whole maestro engine in it. That car used an end-on gearbox not an in-sump like the Mini. The block also faced the other way around with the dizzy facing the firewall. If you swap the crank then you can fit it to a mini gearbox.
I also doubt it has the maestro inlet manifold as this had a 180 degree turn in the manifold so the carb would hit the bonnet in a mini.
#4 Rusty1182
Rusty1182
  • 389 posts
Posted 02 August 2017 - 06:01 PM
The engine is already in and working and driving.    i was just wondering what the differences would be when ordering parts for it.
#5 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 02 August 2017 - 06:13 PM
Oil filter is different, goes straight onto the block like an mpi mini.
#6 nicklouse
  • 18,577 posts
Posted 02 August 2017 - 06:33 PM
i would just wait untill you get it as it may not what people are telling you or may not as original.
#7 midridge2
midridge2
  • 1,794 posts
Posted 02 August 2017 - 07:24 PM
You may mean its a metro engine.
#8 MacGyver
MacGyver
  • 1,027 posts
Posted 02 August 2017 - 07:26 PM
Maybe it's a metro engine?
My dad had a maestro that died a year ago... RIP... And I scavenged what I could from it and the block was unusable unless major work was done to it.
It has the same'ish' block but it has completely different innards...
#9 Tupers
Tupers
  • 4,143 posts
Posted 02 August 2017 - 08:01 PM
I put a 1300 Maestro engine into an Austin 1300 in 2015 and it's pretty easy.
The only major mechanical difference is the crankshaft but I had a good A+ one that I swapped in with the bearings.
The oil pickup in the bottom of the block is also larger as the Maestro has a threaded fitting there. To get over this I cut the fitting down to be flush with the block and screwed it in with a bit of loctite.
All in all it's a reasonably simple conversion as long as you're familiar with Mini mechanics.
#10 MacGyver
MacGyver
  • 1,027 posts
Posted 02 August 2017 - 08:24 PM
Darn, why did I listen to them! 😒
#11 Tupers
Tupers
  • 4,143 posts
Posted 02 August 2017 - 08:29 PM
Here are a couple pictures from the conversion. I didn't take any detailed pics of the differences unfortunately but they're really not that far apart.
Interestingly if you we're looking to add air-con and other auxiliaries to a Mini as I am these blocks are ideal as they have many more mounting lugs cast into them.
#12 Rusty1182
Rusty1182
  • 389 posts
Posted 02 August 2017 - 08:40 PM
Thanks for the comments looks like its a normal kind of engine swap then
#13 nicklouse
  • 18,577 posts
Posted 02 August 2017 - 08:51 PM
well it is basically the MPI block.  but the Maestro power unit is very different.
#14 mini13
mini13
  • 3,810 posts
Posted 03 August 2017 - 12:36 PM
dosent the maestro block have the oil pickop pipe changed to be like the inline engine, also isnt there rear main bearing differences for a rear oil seal.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 August 2017 - 10:10 AM
Nope, straight swap...
Replace the crank for a mini one and off ya go...
Old A series inline engines, Midget, Marina and Ital do have to have the rear main cap modified...
