Wiring Question Not Really Mini But On A Mini How To Wire Some Switches.
electrical
Best Answer nicklouse , 03 June 2018 - 08:37 PM
all done and dusted works as planned. Go to the full post
27 replies to this topic
#1 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 07:27 PM
Ok Wiper motor.
three wires
earth sorted.
2 lives
1 live will power the wiper but will not start the motion
2 live will start the motion. (and keep the motion going even if 1 is disconnected)
so if i have 1 connected nothing happens until i trigger it with say a Mom. switch on 2. it will then stop until triggered again
then if i have 2 connected the wiper will run until switched off but it will stop at the switch off point no home return which is there with 1 connected.
how would you wire this up
i can do the single wipe and self park with a OFF/ON/ON+MOM  but the continuous with self park has me stumped.
i am thinking it will be two switches.
#2 Mervyn
Mervyn
  • 256 posts
Posted 30 July 2017 - 07:40 PM
Right, last time I did this it made my brain hurt as I seem to remember I bought a triumph spitfire switch to get
an xjs wiper motor working on a Kitcar as I couldn't figure it out. I'm pretty good with wiring but that had me pulling my beard out
Here's a thread on retro rides, any help?
http://forum.retro-r...er-motor-wiring
Merv
Edited by Mervyn, 30 July 2017 - 07:41 PM.
#3 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 07:52 PM
yes kinda. changed my thinking the 1 conection should be live 24/7 as it is actually off (could be switched as an override).  then if i use a on/off/mom that should work fine .
#4 phillrulz
phillrulz
  • 617 posts
Posted 30 July 2017 - 08:29 PM
Hmm so your saying there is two lives
Live 1 (park switch contact Live )  - will power the wiper but will not start the motion
Live 2 (Run Live ) - Triggers the motor to start  (and keep the motion going even if 1 is disconnected)
If Live 2 is powered but Live 1 is dead ,  the motor runs continuous
If Live 2 is powered but Live 1 is dead and Live 2 is disconnected the motor stops instant no park
If Live 2 and Live 1 is Powered , motor runs continuously
If you keep both live then disconect Live 2 the motor parks and stops?
If you Make both live then disconect Live 1 the motor keeps going
As for if both are dissconect the motor should stop instant
Is this all right?
Edited by phillrulz, 30 July 2017 - 08:31 PM.
#5 Swift_General
Swift_General
  • 871 posts
Posted 30 July 2017 - 08:39 PM
You could use a single 2 position 2 way (ON/ON) switch here. Wire your 2 positive feeds to the 2 outputs from the switch. That way when switch is in position 1, live 1 only is energised so self park function operative (effectively your OFF postion). When switch is in position 2 the live 2 is energised so starting the wiper. Not clear if you need live 1 to be energised for live 2 to be able to start wiper. If you do the just wire a diode across live 1 and live 2 such that current can only flow from live 2 to live 1. That way when switch is in position 2 (effectively your ON postion), live 1 and 2 are energised so starting the wiper. Turn the switch to position 1 (OFF) and live 1 only is energised so wiper continues until parked.
#6 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 08:44 PM
If you keep both live then disconect Live 2 the motor parks and stops? yes
If you Make both live then disconect Live 1 the motor keeps going yes
As for if both are dissconect the motor should stop instant yes
Is this all right?
see the red above
#7 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 08:49 PM
no it does not if 2 is powered up only the wiper works and stops where you switch it off it is also needed to override the auto stop in the self park.
i am thinking i will do best with two switches in series.one off/Mom and one on/off
#8 phillrulz
phillrulz
  • 617 posts
Posted 30 July 2017 - 09:21 PM
Is this all right?
see the red above
And all the rest ?
This is the image i used to get my head around it
Then you want to keep 2 permanently live this is park switch then switch 1 which is the run connection
Live 1 = 53 Live 2 = 53a
Could get just a Mom/Off/On.
My rough paint rework
Make sure you agree before you go buying stuff :)
#9 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 09:39 PM
looks like a MOM/OFF/ON will do if i can find one.
#10 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 09:57 PM
not finding any so i think i will add a Mom switch.
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 30 July 2017 - 10:03 PM
Have you looked here http://www.mouser.co...icing|0&FS=True
#12 phillrulz
phillrulz
  • 617 posts
Posted 30 July 2017 - 10:30 PM
Could get away with a simple SPST just means you cant use the momentary function do do a single wipe you would have to toggle it on and off to get it.
Or as you say put a mom in parallel to a SPST
Edited by phillrulz, 30 July 2017 - 10:31 PM.
#13 weef
weef
  • 479 posts
Posted 30 July 2017 - 10:40 PM
HI  you don,t say the age of the vehicle but on early three wire motors they worked by switching to earth. There was one fixed earth sometimes marked E, one switched live via an ignition supply usually terminal 2 and terminal 1 was switched to earth via the wiper switch, this was for single speed motors and I think in the two speed set up a third brush was fitted in the motor and the second speed switch possition put 12v onto it. Wiper wiring can be confusing but you have to remember its the switching to earth. The self parking works internally on the motor by open circuiting the internal earth return once the switch earth is removed by turning to the off position.
I hope this helps you understand the wiring setup.
#14 nicklouse
  • 18,474 posts
Posted 30 July 2017 - 10:57 PM
like i said NOT Mini
#15 weef
weef
  • 479 posts
Posted 31 July 2017 - 01:16 PM
The same principle applies.
