Hi all
Trying to remove the injector from my spi to check it/ clean it.
I've left everything in place as it all seems accessible.
I've removed the bolt at the top and disconnected the wiring.
Have eased the top and the yellow cap comes off leaving the rest in the housing.
What's my next step, don't want to guess and end up breaking anything.
Also when reassembling how do you get the yellow cap back on? Does it need a bit of lube to get the o ring back in so it sits tight?
Nic
Injector Removal
idlethumbs
, Jul 24 2017 12:52 PM
3 replies to this topic
Posted 24 July 2017 - 12:52 PM
Posted 26 July 2017 - 06:44 PM
You need to have the whole injector housing off the throttle body and on the bench. Do this by removing the four torx screws and lifting the injector housing away from the throttle body.
After you have removed the injector connector cap by removing the single retaining screw, place the bottom of the injector (the yellow plastic shroud part) flat on a smooth hard surface and apply even downward pressure on the injector housing. The injector should pop out. Be careful not to damage the plastic shroud.
Use a little oil on the Orings when re installing
You really need the injector to be ultrasonically cleaned while being pulsed with a cleaning fluid flowing through them. My advice is to have it cleaned and flow tested at a specialist as a quick buff and a soak won't really do much
Edited by Sprocket, 26 July 2017 - 06:48 PM.
Posted 26 July 2017 - 09:52 PM
Thankyou Sprocket
Excellent advice as usual.
Posted 10 January 2025 - 12:16 PM
Just a couple of points to add to Sprockets advice here.
1. The bottom of my injector was green not yellow. Dunno why.
2. If you do remove the injector housing from the body you will likely require a new gasket - which as Ive found it quite hard to get and pricey for a gasket (about £7 thanks Roger @ NLA Minis ) Part # JZX3064
3. You will have to remove the black plastic connector and also the 2 fuel pipes from the housing also.
Was gonna post some pics but dont seem to be able to...
Edited by orac69, 13 January 2025 - 09:50 AM.
