Crank End Float
Posted 23 July 2017 - 09:24 PM
Posted 23 July 2017 - 09:59 PM
Posted 24 July 2017 - 02:54 AM
stick with what you've got, I aim for .005" - better off with too much than too little - too little can grab when the crank flexes at high RPM
Edited by simon k, 24 July 2017 - 02:55 AM.
Posted 24 July 2017 - 07:24 AM
5 thou is dead right
Posted 24 July 2017 - 02:26 PM
Checking end float with dial gauge I have 5 thou thrust washers fitted either side as recommended by machine shop and said to check it , the dial gauge is showing 0.12mm end float which I think is 4.7 thou end float of math is correct this is to big??? Next size available seems to be 10 thou washers with will make it too small or an I missing something ???
Near to Perfect.
Posted 24 July 2017 - 03:08 PM
