Steering Column Splines
11 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 17 July 2017 - 03:43 PM
Is there supposed to be a flat bit on the steering columns splines where it connects to the steering rack at the floor?
I can't tell on mine if its meant to be like that or has it worn away?
#2 SolarB
SolarB
  • 1,385 posts
Posted 17 July 2017 - 04:15 PM
My first reaction was no, there shouldn't be any missing splines. However, if you think about the way the pinch bolt works there probably should be a section of missing splines either side of the split. Hold on a few minutes and I'm sure someone else will be along with a photo.
#3 minimans
minimans
  • 411 posts
Posted 17 July 2017 - 05:59 PM
I just checked two columns and they both appear to have splines in that area, but they are worn as in your picture so no definite answer from me! has anybody got a NOS column to check?Attached File  FullSizeRender.jpg   23.37K   25 downloadsAttached File  IMG_1345.JPG   36.71K   21 downloads
#4 pusb
pusb
  • 1,216 posts
Posted 17 July 2017 - 06:18 PM
I just checked two columns and they both appear to have splines in that area, but they are worn as in your picture so no definite answer from me! has anybody got a NOS column to check?attachicon.gifFullSizeRender.jpgattachicon.gifIMG_1345.JPG
Your right they look worn in your picture, but not as worn as in mine.
Suggests that the bit by the pinch bolt is the first bit to wear out maybe?
Worth pointing out though that I hadn't had any problems with steering, I have removed the column for a general resto.
#5 minimans
minimans
  • 411 posts
Posted 17 July 2017 - 10:02 PM
Could be that when you tighten/over tighten the pinch bolt that it tears off that part of the spline because that part will try to squeeze together and is softer than the column itself?
#6 nicklouse
  • 18,389 posts
Posted 17 July 2017 - 10:04 PM
the rest look like new. not concerned.
#7 Wim Fournier
Wim Fournier
  • 177 posts
Posted 18 July 2017 - 11:55 AM
Since you have seen the damage, the question is: Are you ready to dy yet? If no, do a proper repair.
Buy new. You won't like it when your car is -all of a sudden- is not listening to your movements of the steering wheel.
#8 nicklouse
  • 18,389 posts
Posted 18 July 2017 - 12:06 PM
damage? what damage.
#9 minimans
minimans
  • 411 posts
Posted 23 July 2017 - 08:31 PM
Buy new from where?..........................
#10 nicklouse
  • 18,389 posts
Posted 23 July 2017 - 09:26 PM
most Mini sales places do them http://www.minispare...|Back to search but i still do not see any damage.
#11 Ethel
  • 25,815 posts
Posted 23 July 2017 - 10:37 PM
Agree, they look fine. They won't wear from being over or undertightened, at least not unless it's so slack for the steering to be sloppy. Wear is most likely the result of misalignment causing the splines to slide along each other as the column turns.
#12 Pete649
Pete649
  • 374 posts
Posted 24 July 2017 - 07:20 AM
I seem to remember that the older inners had splines all the way round including right up to the gap whereas later (aftermarket?) inners were more like the ones in the first photo with the splines stopping short of the gap.
Also, the pinch bolt hole in later inner shafts (that I have seen) is drilled slightly further out making the interface / interference with where it connects onto the the steering rack shaft less.
Edited by Pete649, 24 July 2017 - 02:42 PM.
