1979 Mini City 850
83 replies to this topic
#61 pusb
pusb
  • 1,216 posts
Posted 16 February 2019 - 03:45 PM
Rear brake pipes all connected up
#62 Jase
Jase
  • 1,166 posts
Posted 21 February 2019 - 09:58 PM
Realised that I hadn't fitted the handbrake quadrants, so radius arms had to be taken back off.
Very frustrating, as its a very fiddly job once everything is fitted
Eeek, I haven't fitted my quadrants yet and it's on four wheels, does that mean complete removal or is there an easier way?
#63 pusb
pusb
  • 1,216 posts
Posted 22 February 2019 - 05:57 AM
Undo the shock absorber, then the bracket that holds the radius arm on, then the big nut that holds the radius arm to the bracket. Leave the nut on the inside of the subframe that secures the radius arms.
With the bracket and outside nut removed, the radius arm should then slide out on its pivot pin. This will give enough room to fit the quadrants.
#64 Jase
Jase
  • 1,166 posts
Posted 22 February 2019 - 07:07 AM
#65 pusb
pusb
  • 1,216 posts
Posted 02 March 2019 - 05:32 PM
Got the brake calipers fitted, so I could then fit the subframe brake lines
#66 pusb
pusb
  • 1,216 posts
Posted 02 March 2019 - 07:36 PM
Great progress and thanks for all the detailed pictures.
I have an 87 in a very similar condition to yours. I am currently where you were around Jan last year on my project. Can you please share the company who shot blasted your subframe?
Also, how much did it cost for the shell repair and painting?
Hi,
Sorry I only just seen your post here, hope you didn't think I was being rude by not replying.
The shotblasting was done by a company called Midland Surface Finishers.
The bodywork and paint come to around £3.5k
#67 pusb
pusb
  • 1,216 posts
Posted 03 March 2019 - 03:36 PM
I bought these brake pipes as a kit, as they were supposedly made to measure.
I don't know what they were measured against though, as it certainly wasn't a Mini
#68 pusb
pusb
  • 1,216 posts
Posted 09 March 2019 - 03:05 PM
Rear section of the handbrake cable in place.
Had trouble getting it to stay in the quadrants (sick of those things), I'm guessing that is because there's no tension on the cable at the moment?
#69 jamesquintin
jamesquintin
  • 1,017 posts
Posted 09 March 2019 - 03:24 PM
With those pipes, have you bought a left hand kit...?
I've seen so many 'kits' on here that are clearly not the right length that it forced me to buy a long line of pipe and make my own fittings...
Q
#70 pusb
pusb
  • 1,216 posts
Posted 09 March 2019 - 03:52 PM
Q
Well it said RHD on the invoice.
Its a bit annoying because the whole reason I bought the kit was so I didn't have to start buying flaring tools etc. But I'm going to have to now anyway
#71 imack
imack
  • 2,096 posts
Posted 09 March 2019 - 04:14 PM
Both ends of the quadrant should be crimped with a pair of pliers to grip the cable ad stop it coming out.
#72 pusb
pusb
  • 1,216 posts
Posted 09 March 2019 - 04:46 PM
Thanks, I will do that
#73 pusb
pusb
  • 1,216 posts
Posted 30 March 2019 - 01:40 PM
Handbrake finally fitted. What with the quadrants and messing about with the cable, it feels like its taken me forever to get a functioning handbrake!
#74 pusb
pusb
  • 1,216 posts
Posted 06 April 2019 - 06:10 PM
Riveted the rear ashtray into place, thought the chrome bit was looking a bit grubby though so had a go at cleaning it up
Ignore the phone book in the background!
Then had a go at it with some Brasso
Looking nice and shiny in place
Then started on some sound deadening
I've got the sound deadening mats underneath with the foam isolation stuff on top. I want this to be a quiet Mini!
I did want to start with sound deadening the floor first. But due to the groves in the floor, I thought it best to get one of those little roller tools to make sure the pads have proper contact with the panel.
Unfortunately, after ordering a roller tool, I got it delivered to work, and then left it there yesterday  :goaway:
#75 pusb
pusb
  • 1,216 posts
Posted 07 May 2019 - 04:54 PM
Soundproofing all finished, and got the wiring loom back in. Now there's a part that comes out a lot easier than it goes back in!
