1979 Mini City 850
83 replies to this topic
#16 pusb
pusb
  • 1,216 posts
Posted 20 January 2018 - 12:14 PM
So after a holiday, Christmas, illness, and general laziness, I got back onto looking at the Mini this morning. I've decided to get a professional to do all the shell work, I will just do the strip down and reassembly. I'm thinking of using The Real Mini Company in Oxford.
Still trying to get the subframe off. The lower front mounting bolts (which both sheared) I managed to cut through using a saw. This allowed me to completely free the drivers side.
This allowed me to get a proper look at the corrosion behind there
However the top bolt still seems to be holding it on. I cannot see where it is still attached. The bolt sheared, but it is still holding it in place somehow. There isn't enough room to get a saw in there to cut through it.
#17 pusb
pusb
  • 1,216 posts
Posted 22 March 2018 - 07:55 PM
Not updated this for a while. I managed to get the subframe off in the end, had to get a small saw up through the gap and cut through the bolt. To do this I had to removed the radius arm, which made access a lot easier.
I then got the engine and front subframe out, which allowed a clear view of the condition of the shell.
Front subframe seems completely fine. Think I will get it shot blasted and then either painted or powder coated. Whats everyone's thoughts on that?
The engine was running fine, however the clutch was causing a slight problem so I will look at that before the engine goes back in.
For now anyway the priority is the bodywork
#18 pusb
pusb
  • 1,216 posts
Posted 22 March 2018 - 07:56 PM
#19 pusb
pusb
  • 1,216 posts
Posted 22 March 2018 - 08:05 PM
Finally got it out of the garage anyway, and its been sent off for repair. No way could I tackle that welding!
I've bought the first new shiny bits! Some new black bumpers
And attempted to dismantle the rear subframe. The radius arm on one side is stuck. Two of the bolts undone, the other two are stuck solid and are just rounding off.
I've managed to get the trumpet out from the other side. How do you get the cone off though? Its seems impossible to remove.
The front shocks had no resistance left at all. Compress them and they just stay compressed.
I'm not sure what to do with my steering rack. I don't think there is anything wrong with it, however due to its inaccessible nature, am I just as well to put a new one in?
#20 johnR
johnR
  • 2,322 posts
Posted 23 March 2018 - 04:13 PM
I would suggest having the front subframe blasted and powdercoated.  The powdercoating seems able to resist brake fluid spills much better than paint.  if you're replacing the cones heating the metal centre part may help dislodge them - but it might be a good time to replace the trumpets with adjustable hi-Los then you don't need to bother!
Edited by johnR, 23 March 2018 - 04:21 PM.
#21 johnR
johnR
  • 2,322 posts
Posted 23 March 2018 - 04:17 PM
The shox shouldn't rebound - there's no spring in them - the fluid in them just passes through small holes thus damping the action of the rubber cones
#22 pusb
pusb
  • 1,216 posts
Posted 23 March 2018 - 05:26 PM
Thanks, I didn't realise that.
I will replace them anyway though I think. The old ones were looking manky!
#23 lawrence
lawrence
  • 1,341 posts
Posted 23 March 2018 - 10:13 PM
Check for play etc with the rack but if there's no problems simply regrease it and refit it. Also don't change the rubbers unless they are warn as some of the new rubber parts quality is poor.
#24 johnR
johnR
  • 2,322 posts
Posted 24 March 2018 - 04:22 PM
New standard shox aren't very expensive and yours do look a bit battered! I used new standard ones in my re-build a couple of years ago and have found the back end quite bouncy - I guess you get what you pay for and perhaps the lightweight back end of a mini needs something better?
#25 Oceanspeed
Oceanspeed
    Starting My Mini Up
  • 1 posts
Posted 09 April 2018 - 11:49 AM
Hi, great posts and photos of your progress so far!.  I have an original 850 city from 1979. You are correct in that there are very few left. Most have been modified away from original release.   Purchased in 2014 and have spent the past 3.5 years fully restoring it back to factory. Has about 38,000 on the clock.  I'm getting pretty close to finishing now and will put some pics up soon showing the journey... take loads of photos and make notes, you will definitely need them..
#26 pusb
pusb
  • 1,216 posts
Posted 15 April 2018 - 09:11 PM
Great that you also have one. I'm trying to get mine back to as close to original as possible. It will have a 1275 engine in it, and disc brakes, but that's it. I do still have the original 850 engine though, has about 90k on it. Still ran fine but was using a bit of oil.
#27 johnR
johnR
  • 2,322 posts
Posted 16 April 2018 - 10:31 AM
If you're going for originality I would suggest re-fitting the 850 engine as that is one of the major things that defines it - keep the 1275 for the next project!
#28 pusb
pusb
  • 1,216 posts
Posted 17 April 2018 - 06:06 PM
It will be refitted at some point.
#29 pusb
pusb
  • 1,216 posts
Posted 17 April 2018 - 06:10 PM
Front subframe stripped down. Getting this blasted then I will paint it
#30 CharlieNZ
CharlieNZ
  • 69 posts
Posted 17 April 2018 - 08:09 PM
Nice progress on what will be a nice mini. Looking at that shell, it's good that you caught it now, and also good that it's being done professionally. Someone has clearly put a lot of love into this mini in the past.
When is the shell due back?
