Baulk Ring Wear
4 replies to this topic
#1 mini_cooper_s
mini_cooper_s
    Just On Tickover
  • 7 posts
Posted 27 June 2017 - 04:35 PM
Hi,
Im rebuilding gearbox, and trying to sort out if I need to replace my baulk rings.
The one with the least gap, has a gap of 0.6mm (the one on the first motion shaft) the others has 0.9-1mm gap.
Do these need replacing?
Attached File  IMG_8571.JPG   27.8K   14 downloads
#2 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 27 June 2017 - 08:25 PM
If your rebuilding the box, replace the baulk rings anyway.
They are not expensive, just make sure you get good ones and not budget ones!
#3 Spider
  • 14,843 posts
Posted 27 June 2017 - 08:26 PM
The wear limit is 0.030" (0.76 mm).
#4 mini_cooper_s
mini_cooper_s
    Just On Tickover
  • 7 posts
Posted 28 June 2017 - 06:17 AM
Thanks,
Will these be good enough?
http://minispares.co...|Back to search
Edited by mini_cooper_s, 28 June 2017 - 06:18 AM.
#5 imack
imack
  • 2,104 posts
Posted 28 June 2017 - 06:22 AM
I've used those minispares ones in the past with no problems.
