Where Can I Get A Brake Servo Filter ?
Best Answer tiger99 , 17 June 2017 - 09:43 AM
Felt disc would be more like it. You need quite a fine material. Scotchbrite is far too coarse. Maybe something cut from a face mask might be suitable? You probably get refills for them in Screwfix or Toolstation.
In my ancient Rover P4 the filter element lived inside a plastic cap that went over a stub on the body and was vented at the bottom edge so it was sort of like a miniature air filter and could be made like one from the same material. But in your case I can picture it clearly as I have seen them, and that technique would not work. Go to the full post
7 replies to this topic
#1 sledgehammer
sledgehammer
  • 3,098 posts
Posted 16 June 2017 - 02:31 PM
where can I get a brake servo filter ?
is it possible to make one ?
they seem to not be available any more
blocked / collapsed ones can affect braking
or are they not necessary anymore - surly air entering the servo needs filtering ?
or am I just an old f@rt worrying about nothing
Edited by sledgehammer, 16 June 2017 - 02:32 PM.
#2 nicklouse
  • 18,584 posts
Posted 16 June 2017 - 04:13 PM
Which servo is it?
#3 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 16 June 2017 - 05:36 PM
Servos have filters? Only thing I know of on the lines is the non-return valve
#4 tiger99
tiger99
  • 8,584 posts
Posted 16 June 2017 - 05:49 PM
Yes, they have always had filters. I faced a similar problem in 1973, not on a Mini, when the part I needed had gone obsolete. I improvised by making a new filter from a cut-up piece of air filter, the zig-zag stuff, neatly taped at the join and squeezed into its plastic housing.
But as I don't know which servo you have and into what space the filter must go, I can't tell whether that will work for you or not.
The filter for the later servo is still available here:
http://www.somerford...roducts_id=3589
Failing that, Google for a servo rebuild specialist and see if they stock repair kits, which may contain a filter.
#5 sledgehammer
sledgehammer
  • 3,098 posts
Posted 16 June 2017 - 08:24 PM
sorry I didn't think - it's a 1989 mayfair
bolted to bulkhead , non remote , filter behind rubber cap
took old one out  in a million bits , with a lot of dust
vacuumed the area , think I got all the carp out
wondering if a bit of scotch brite pad will work
or vacuum cleaner bubble mesh type filter -
I want something in there , the old one def stopped a lot of crud before it died
or maybe felt discs with a hole in , for push rod
Edited by sledgehammer, 16 June 2017 - 08:25 PM.
#6 nicklouse
  • 18,584 posts
Posted 16 June 2017 - 08:49 PM
some of the air filter foam?
#7 tiger99
tiger99
  • 8,584 posts
Posted 17 June 2017 - 09:43 AM   Best Answer
#8 sledgehammer
sledgehammer
  • 3,098 posts
Posted 17 June 2017 - 01:24 PM
I got face masks  , good idea
I reckon that will do
used to change them when I was an apprentice , can't remember doing a mini filter
they seem to be ignored now , unless they have a different way of doing it
Edited by sledgehammer, 17 June 2017 - 01:27 PM.
