My up and coming r1 mini.
#61
Posted 29 March 2007 - 02:25 PM
ta
phil.
#62
Posted 29 March 2007 - 05:00 PM
Not sure if the carb and injection are the same but here is how mines connected. Its just put on loosely to show you!
#63
Posted 29 March 2007 - 05:16 PM
#64
Posted 09 May 2007 - 11:09 PM
#65
Posted 13 May 2007 - 10:49 PM
Pics below, more to follow.
Having a nightmare with the brakes, the goodridge kit I bought - was sure it was a copy - can you believe the entry points into the 4pots were cast! I couldn't, then I overtightened one and lost a lot of bleeding time
Not got much left now, althought I keep seeming to say that...just got my fan installed, my battery held down and cabling to/from it done. Awaiting a new goodridge kit as I could not find anyone to manufacture me the part they produce in good quality stainless, so having to try with the same kit again, this time from a reputable retailer in the hopes that the one I got from Ebay was no good.
Bought some arches from p&l that were advertised as fitting my 13*7 wheels, they went nowhere near, but they refused to take them back so I sold them on ebay as I had no legal redress after looking at the law (long boring story best forgotten, just avoid them as their customer service in my case was lousy, they put the phone down on me and banned my email address even before I raised my voice or swore, and this was after I had given them a few handy hints on google ratings - gives me an idea for a new category actually, companies with good service records and companies that give bad service, what about it admins - enough mini people here to get the data for it and would provide a good resource for future purchasers, as long as posts were factually correct, it would be fine.
TO DO
Got to connect up the accel cable,
Get hold of a thermostat for the rad and wire the fan,
I have bought one of the acewell speedos for the dash, (nice and neat) that needs to be wired in,
Bleed the brakes - again,
Shorten my clutch pipe,
Fit a wiper motor,
Fit some arches - if I can find any to fit - help? 13*7 deepdish superlights fitted,
Get some welding done, I have too many holes left over from my last rollcage fittings that need to be dealt with,
Extend the exhaust, for some reason, my exhaust does not fit properly, the pipe from the manifold does not stick out far enough to stop the casing of the exhaust hitting the metalwork under the diff before it is properly fitted home,
Fit seat and harness,
Fit windows back in,
Retighten all bolts.
Bound to be other stuff - you get the idea
more soon
phil
ps the rust comment is in relation to my garage - its half finished and the water gets in so things are going off quite quickly..still intend a reshell after I have had some use out of it and have a better idea of what I am doing
Posted 13 May 2007 - 10:54 PM
#67
Posted 15 May 2007 - 06:22 AM
Posted 15 May 2007 - 06:37 AM
And what year is the engine inj or carb?
#69
Posted 15 May 2007 - 08:03 PM
#70
Posted 20 May 2007 - 10:14 PM
Fuel pressure gauge fitted.
Posted 21 May 2007 - 04:17 AM
Wicked project you have there. If it's arches you are after then try Dave here http://home.freeuk.c...ng/products.htm. Very good quality and excellent price
Paul
#72
Posted 21 May 2007 - 08:26 PM
#73
Posted 12 December 2021 - 09:15 AM
Car is now mot'd and taxed.
Except, they are never really finished are they...?:)
Issues I have to sort...may help gratefully received
Most pressing...
Idle is fine and car revs freely..but under load misfires badly and has top speed of around 30mph..
I am guessing this is a quick fix...I am thinking ...
Either is because the fuel tank gravity feeds the high pressure fuel pump and not enough fuel gets to pump..so without load it's fine, with load it isn't.....my fix for this would be to install solid state pump 4-5psi pump between the tank and filter to give more consistent delivery to the hp pump.
Or
The fuel return pipe from injector rail to tank is not large enough diameter and it's blowing the fuel rail open and drowning the engine..
Else something wrong on bike engine.. sensor etc.
I can't see it being anything other than quick fix but how best to diagnose which quick fix is needed?
Although the brakes are not standard I will be updating them to alloy front four pots
I currently have rubber fuel line and this will be swapped out for braided
Also going to braided brake lines to rear calipers.
#75
Posted 08 March 2022 - 05:52 AM
Congrats on the end result. And I thought I was the only one that took forever to get the project done:)
