My up and coming r1 mini.
75 replies to this topic
#46 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 19 October 2006 - 10:04 AM
Top arm, at the mo its angled up just over horizontal.
#47 R1mini
R1mini
  • 1,387 posts
Posted 19 October 2006 - 10:20 AM
This picture shows where a normal mini suspension would be, you can see already the top arms are at an angle, you can drop another inch lower from here easily
David
#48 Jammy
Jammy
  • 25,397 posts
Posted 19 October 2006 - 11:08 AM
OMG, R1mini, I want to kiss you! Is that a scale drawing? Have you got any other drawings like that, particularly showing measurements for the suspension system, and the hub?
#49 ed4ran
ed4ran
  • 2,849 posts
Posted 19 October 2006 - 11:09 AM
Thats what mines like at the moment.
#50 R1mini
R1mini
  • 1,387 posts
Posted 19 October 2006 - 11:59 AM
Jammy there is no need, I'm sure about that. They are not my drawings I just found them on the web have a look here for more
http://home.earthlin...0/mini_susp.htm
Ed
I have a picture of the front suspension on R1minimagics car on my other computer I will post it tonight, you can see the top arms are heavily angled, but Dale reported the front end to the best bit of the suspension, only wanted to change it because he wanted to lose more weight and lower it even further
David
#51 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 19 October 2006 - 12:24 PM
I have a 10mm gap between the end of the thrads on the shock and the bottom of the spring seat and my bottom arm is already horizontal so any suspension movement will result in a giving me a reduction in negative camber angle.
#52 R1mini
R1mini
  • 1,387 posts
Posted 19 October 2006 - 01:56 PM
Markrally
As your lowered suspension compresses you will get an increase in negative camber
David
Edited by R1mini, 19 October 2006 - 04:41 PM.
#53 R1mini
R1mini
  • 1,387 posts
Posted 19 October 2006 - 04:46 PM
Hello Ed
Here is a piccie of your coilovers fitted to R1minimagics car
David
#54 ed4ran
ed4ran
  • 2,849 posts
Posted 19 October 2006 - 05:52 PM
I guess my front is lighter as its sitting higher?? ;D
and on the passenger side it is wound all the way down!!
#55 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 19 October 2006 - 06:52 PM
Markrally
David
Quite true David in most normal installations but at rest the arm is horizontal (and not pointing down to the ground as in the sketch above you posted) and at its longest point so giving the most camber, as the hub end of the bottom arm raises under breaking etc pivoting on the rose joint in the subframe so the distance from the car shortens and removes any negative camber by pulling the bottom of the hub inwards. Its easy to check, just remove the spring from the shocker and then work the suspension with the car in the air and with a camber guuge fitted to the wheel mounting face.
#56 R1minimagic
R1minimagic
  • 4,660 posts
Posted 19 October 2006 - 07:44 PM
Ade, you have 180lb springs on the tubular front end???
Mine had 160lbs on the front (mini subframe) and 400lbs currently with the tubular z cars.
However, your spring/dampers are mounted differently so maybe very similar rates to the normal subby. With angled springs (like mine) you need much higher poundage.
#57 philmin
philmin
  • 136 posts
  • Local Club: QQQQQ
Posted 19 October 2006 - 08:26 PM
Cooling query folks: I have never worked on anything apart from mini's so the R1 cooling has me in a bit of a tizz even though I have the ZCars DVD. Anyone mind telling me how wrong my attached diagram is? and even better, correcting it for me?
Will get your brains working anyway ;D
- I have helpfully marked some other bits I am very not sure about in the section titled "other bits" :-
thanks for the help
phil.
Attached File  Cooling.bmp   1.33MB   70 downloads
#58 pete
pete
  • 680 posts
Posted 20 October 2006 - 06:18 PM
The drivers side looks right. The only bit I think you've got wrong on the passenger side is the tiny pipe hidden in bottom of engine next to large intake pipe. This goes up to idle up valve(choke unit ) located on back of throttle bodies. The other pipe from this valve(choke unit) goes into a small pipe located in the head hidden under the throttle bodies. I have listed out my setup below if this helps.
bottom rad hose to large pipe located under sprocket
small hose from this point goes up to the idle solenoid on the throttle bodies
other side of idle solenoid goes to pipe coming out of the head underneath throttle bodies
top rad hose to thermostat housing
alloy 4 way connector piece supplied by z-cars fits into this pipe just before thermostat housing
one pipe from 4 way connector goes to bottom of expansion tank
other pipe from 4 way connector goes to oil cooler
small pipe from thermostat housing goes to top of expansion tank
Mines a 2004 engine but should be the same
Pete
#59 philmin
philmin
  • 136 posts
  • Local Club: QQQQQ
Posted 20 October 2006 - 06:24 PM
Pete
Fab Pete! thanks mate - I have got more correct than I thought! Your above also explains where my two "other bits" fit in - hurrah! thanks a lot.
#60 philmin
philmin
  • 136 posts
  • Local Club: QQQQQ
Posted 25 March 2007 - 07:29 PM
Hi all,
Does anyone know where I can get filter foam for an air filter, that I can just stuff into my own filter casing, rather than buying a ready made filter, surely I must be able to get something similar to pipercross foam in sections and fit it to my requirements or something like that ?
thanks
phil.
