[quote name='markrally73' post='350920' date='Sep 24 2006, 11:44 AM']
[quote name='philmin' post='350743' date='Sep 23 2006, 11:19 PM']
Are you running it via a relay? Or is there no need?
thanks for the help
phil.
[/quote]
You should have a relay in your loom already to power the original R1 pump but if you have only got a fuel pump output from the ECU, you had better run a relay.
[/quote]
thanks guys - need to go through what wires are what then that Chris labelled for me, have a feeling that to demo it running to me he just connected the fuel pump to the battery directly? but I wasn't taking that much notice - had been up since 3am that morning to get to him from Cardif - long way in a c****y van!
not looking forward to fitting the cut off either - its easy enough in a normal mini - had the fuel pressure cut off, oil pressure cut off and the alternator protected - all via the cut-off - want to aim to do the same again really - want it so a scrutineer can't complain ultimately.
[quote name='pete' post='351098' date='Sep 24 2006, 06:50 PM']
Not running it through the bike ecu. Connected via a relay to an ignition live. Should really have one of those cut off switches in case of an accident but couldn't be bothered to fit one
. Not planning on crashing it
[/quote]
[quote name='philmin' post='351205' date='Sep 24 2006, 09:51 PM']
thanks for the help
phil.
[/quote]
[/quote]
[/quote]
[/quote]
Are you off to combe next weekend ? its miniworld action day isn't it?
[quote name='philmin' post='351205' date='Sep 24 2006, 09:52 PM']
thanks for the help
phil.
[/quote]
[/quote]
[/quote]
thanks for the help
phil.
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
that questions to everyone with bike engined minis (BEM's?). Want to see how it all fits together - won't be pinching ideas though - got my own - ta.
phil
