1967 Cooper S - Camshaft Identification
6 replies to this topic
#1 iain1967s
iain1967s
  • 20 posts
Posted 11 June 2017 - 01:07 PM
Hi. I am getting back into the classic mini scene after a break of 25 years...
I just picked up a nice Morris 1967 Cooper S, but it has a 1380 MED engine installed currently, which doesn't really meet my taste for 'factory spec' authenticity :)
The original AEG312 thin flange block (+20) with its cross-drilled EN40B crankshaft were included, so I plan to build the engine back up as near as possible to the spec it would have been in 1967
But I cannot identify if the camshaft that came with the ending is the original AEG510 that should be in a cooper of this age (or if it is at least a close equivalent).
Can anyone possibly identify it from these photos?
The stamping on the duplex timing chain end says "16A73" but I get no obvious hits with google and forum searches etc.
Thanks.
#2 nicklouse
  • 18,576 posts
Posted 11 June 2017 - 05:20 PM
is it spider drive?
#3 iain1967s
iain1967s
  • 20 posts
Posted 11 June 2017 - 06:23 PM
is it spider drive?
No, it's the original peg drive.
#4 carbon
carbon
  • 2,590 posts
Posted 11 June 2017 - 06:40 PM
Pin drive 3/8 inch wide lobes and single ring might be 997 Cooper.
The Cooper S 510 cam also has single ring but should have 1/2 inch lobes
#5 iain1967s
iain1967s
  • 20 posts
Posted 11 June 2017 - 07:35 PM
Interesting, thanks. It does have 3/8" wide lobes.
Guess I need to get some calipers and measure the other components more accurately :)
#6 Spider
  • 14,838 posts
Posted 11 June 2017 - 08:11 PM
Nice look car, sits up well. Is it still on Hydro?
Yeah, that's not an original Cam.
There were a few new 998 Cooper Cams floating about not long ago, AEA630. These are 1/2" Lobe, Pin Drive Oil Pump and the same Profile as the MKI Cooper S.
I bought up a few of these. If you look about (and might take some phone work), you might be lucky enough to find one.
#7 iain1967s
iain1967s
  • 20 posts
Posted 11 June 2017 - 10:16 PM
Yes, still on hydro. The rear camber is way out, but I plan on replacing the minilite clones with original steels.
I know very little history for the car, but its obviously had a rollcage at some point (four bolt holes in each arch) so this could be some kind of customized race cam.
I see some AEG510 still available retail, I need many other parts including an AEG163 head to complete the authentic build (I literally have only crank, block, cam and timing gear), so this is very much a long term project.
Thanks for your interest.
