Rear Subframe Bushes
Posted 07 June 2017 - 01:14 PM
Have been doing some research on the topic
And am still unsure whether to buy the poly versions of the bushes for the rear subframe
Also, the bushes I removed from the trunnions look a lot different to the ones for sale on minispares
Mine were H shaped
They were narrower in the middle of that makes sense
Whereas the ones I have seen have only had one larger side
Any help??
Posted 07 June 2017 - 01:16 PM
Rubber is best for the rear.
there are two types early and new.
early have two smaller and later has one larger. all are interchangeable.
Posted 07 June 2017 - 01:20 PM
So it doesn't matter which rubber ones I get
They will all fit ?
Posted 07 June 2017 - 01:23 PM
They will all fit ?
Ooooo hang on, sorry I am not 100% on the OD of the bush. the ID is the same. the later may be have a larger OD.
my mind was elsewhere.
Posted 07 June 2017 - 01:27 PM
OK the rears are the same for all years.
http://www.minispare...lassic/subframe mount.aspx|Back to search
the fronts were the same as the rear ones on early cars but later ones got larger front ones
http://www.minispare...ic/21A2560.aspx
Posted 07 June 2017 - 02:16 PM
Posted 07 June 2017 - 03:05 PM
Thanks a lot buddy
Will get on ordering some bushes tonight!
For handling always go poly bush. :)
That's what I thought. But a lot of people say they aren't an upgrade at all
Posted 07 June 2017 - 03:41 PM
Posted 07 June 2017 - 05:45 PM
Depends what you're after..... noisy & "tighter" then go poly a bit less harsh and quieter - rubber (they don't exactly need changing often and even then are a doddle to change) .... my preferred option is to solid mount the front sub & rubber the rear.....
Posted 07 June 2017 - 08:01 PM
the poly ones dont last that long.
Posted 08 June 2017 - 11:40 AM
They are of course useless, even dangerous, on front subframe mounts and in particular tie rods.
Poly is much hyped, but like all materials, only useful in the correct places. It is NOT the answer to 99% of automotive suspension problems that the adverts seem to suggest.
The rear subframe mounting bushes have in the distant past been replaced by nylon or felt in by people with access to a lathe. But you will have fun fitting them if the dimensions of the shell and subframe are not exact! Downside is noise transmission.
The later cars, with the rubber mounted front subframe, best done away with, have larger reunions at the front of the rear subframe to accommodate the larger bushes. Simply fit a pair of old style reunions and original rubber bushes and all will be well. The difference between rubber in old style bushes and poly or even solid (nylon/delrin) is insignificant as regards handling, but the later large bushes are somewhat too squidgy (highly technical term!).
