Hi.
My mini has a short somewhere between the lights and the indicator circuits on the RHS of the car. The behaviour is as follows:
1. With the lights off, the indicators work fine
2. With the lights on, the front right headlamp is dim relative to the left (maybe 70%). The front indicator lamp and side light are on slightly (very dimly)
3. When the indicator is switched for the right-hand side, it flashes but flashes fast (i.e., like with a bulb is blown and the circuit resistance is therefore high)
So there is a short in here somewhere which seems to be putting my headlamp and indicator circuit partially in series with one another. Is this most likely in the column switch? Or is it somewhere else in the harness (that would be a pain)?
I'll have to get out with the multi-meter and have a root around, but before I pull the steering wheel off with the airbag wanted to check if this was a known switch problem.
Thanks!
Chris
