I'm using a 3HP, 200L, 10Bar compressor. I've tweaked it a little and it's now putting out 9.0 CFM (actual measured FAD), so I'm now starting think an air fed mask might be a possibility.
For what I can see, masks need anywhere from 5.5 to 7.0 CFM. Once I pull the trigger though, I'll be draining the 200L tank; I'm starting at 10Bar, but what's a typical minimum tank pressure before the mask's safety whistle goes off?
I'm looking at HVLP / LVLP guns in the 7.5 to 10 CFM range, so I'm hoping I'll be able to put down a decent amount of paint quickly. Depending on both the mask and gun that I choose, I'm calculating anywhere from 5 to 12 minutes before I've run out of air. That does sound like plenty to me, but roughly how much could I paint in 5 or 12 min?
It's early planning stage now, so all ideas, comments, suggestions greatly appreciated
