Timing Chain Tensioner - How Tight?
6 replies to this topic
#1 myminipickup
myminipickup
  • 152 posts
Posted 29 May 2017 - 11:36 AM
Hello
I am rebuilding a 1275 A+ and just replaced the timing chain and tensioner - how much tension do I need to apply to the chain? How do you know how much is enough or too much?
Many thanks
#2 wile e coyote
wile e coyote
  • 1,230 posts
Posted 29 May 2017 - 05:53 PM
I'd just bolt the tensioner on.....and at it's minimum adjustment - i.e none , it'll be fine - the new chain will be temporarily nicely tight the only point of the tensioner really is to minimise rattle...(ok ok a worn chain will chuck the timing out about 3 degrees)
I'd have used a duplex set though ..... tentioners optional with those!
#3 Spider
  • 14,849 posts
Posted 29 May 2017 - 07:49 PM
The workshop manuals give no advice other than to refit it.
I have always fitted them as tight as they go.
#4 Boycie
Boycie
  • 1,978 posts
Posted 29 May 2017 - 08:53 PM
I fitted the A+ tensioner/ plate etc to my A series a few years back.  It seemed like a good idea at the time and I suppose it was.. for a few thousand miles.  Then the rattle came back.  I too, could find no advice on how 'tight' to fit the tensioning shoe, so fitted it with light hand pressure.  Not very scientific I'm afraid.  I think I'd apply more pressure next time (like Moke says above) as the rattle is back as loud as ever again.  I think it was quiet for around 6000 miles.
#5 myminipickup
myminipickup
  • 152 posts
Posted 29 May 2017 - 10:32 PM
Thanks for your help.. I'll just push it against the chain then I guess!?
#6 Boycie
Boycie
  • 1,978 posts
Posted 30 May 2017 - 04:48 PM
I'd say so. It's a bit of an afterthought setup I think.. and worth remembering that noisy chains rarely cause trouble unless they get really bad!
#7 Cooperman
  • 23,278 posts
Posted 30 May 2017 - 05:17 PM
Fit a Duplex chain and sprockets and forget about the tensioner. That's what the Mk.1 Cooper 'S' had.
