Head Gasket
18 replies to this topic
#16 carbon
carbon
  • 2,590 posts
Posted 02 June 2017 - 04:51 PM
The other issue which can affect some of the A-Series heads is brass plug recession.
There are about 5 brass plugs fitted into some of the A-Series heads, and the centre one overlaps the gasket ring for cylinders 2 and 3 on the 940 head. These can sometimes shift, and effectively create a recess which may allow leakage and gasket failure.
If you have these brass plugs fitted worth checking they have not moved any time you take the cylinder head off.
#17 tom1
tom1
  • 323 posts
Posted 03 June 2017 - 05:21 PM
Hi, thanks for all the advice and interest. studs,my Payen gasket and other bits are here so here we go. My torque wrench was bang on and the block looks flat.
#18 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 03 June 2017 - 06:58 PM
How have you measured to find out if the block face is completely true?
#19 tom1
tom1
  • 323 posts
Posted 03 June 2017 - 08:02 PM
Yes I did, looks OK. Head is on and gaps all set. I don't have any exhaust sealant so have come in for the night.
