Electric Or Mechanical Oil Temp Gauge
19 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 May 2017 - 06:47 PM
Which is preferred?
Both as accurate as each other?
The electric is around half the price (Smiths)
#2 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 25 May 2017 - 07:09 PM
Im running a tim oil temp gauge.
Electronic version.
Seems to be acurate enough.
If you use a mechanical gauge you have the chance of oil leaking behind the gauge if your not carefull when you install it.
At least with an electronic version there is no oil to leak behind the gauge
But you could still have an oil leak where the sender goes into the block, use ptfe tape that will reduce the chance of that happening
Now as im running oil pressure gauge as well,i have a t piece screwed into the block then original sender into thet.
I cant use oil temp sender in t piece so ive had to buy a sandwich plate for my oil filter housing to take the oil temp sender.
Edited by Rapidmini59, 25 May 2017 - 07:11 PM.
#3 nicklouse
  • 18,579 posts
Posted 25 May 2017 - 07:30 PM
i always like mechanical no Voltage variances effect.
#4 wile e coyote
wile e coyote
  • 1,230 posts
Posted 25 May 2017 - 07:47 PM
Capilliary (mechanical) is generally more accurate but both do the job... as an optional nice to have I'd go electrical...
#5 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 25 May 2017 - 07:57 PM
I've always run smiths mechanical gauges with no leaking and 100% reliability
#6 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 25 May 2017 - 09:53 PM
Mechanical are probably more accurate and reliable. I guess electric are really only a guide. If you have one fitted it may pay to compare it with a thermometer to compare and check its accuracy.
#7 Spider
  • 14,843 posts
Posted 26 May 2017 - 03:24 AM
As the other guys have said, the Capillary Gauge is more accurate and considered (though debatable) more reliable, however, apart from being dearer to buy, are not a easy to install, especially in a panel that has many gauges or other accessories in it.
For many years I would only fit capillary gauges, but more recently turn to electric for ease of installation. Now I'm used to it, I doubt I'd go back. I find it just as good for letting me know if all is well or not as the mechanical gauge.
#8 greenmini1275
greenmini1275
  • 348 posts
Posted 26 May 2017 - 07:22 AM
I've got mechanical, the less electrics the better for me.
#9 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 26 May 2017 - 09:49 AM
The mechanical ones can be a bit of a pain, I have the single oil pressure / water temp Smiths and it can get a bit busy behind the dash.
#10 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 May 2017 - 10:26 AM
Great comments  - much appreciated.
I think I will go for the electric one, using the between the block and filter housing sandwich adapter somerford minis sell.  I will need to double check but I think that will allow me clearance to use a Mocal sandwich plate (with stat) between the filter and the filter housing so i can fit an oil cooler into it. And use a short filter.
This seems like a neat install, I think.
#11 Ethel
  • 25,920 posts
Posted 26 May 2017 - 10:33 AM
I think a mechanical oil pressure gauge is more worthwhile and more responsive so you should already be plumbing oil in to the back of your dash is your considering an oil temperature gauge, admittedly you'd need an extra oil line.
You could also ask why you'd want to know your oil temperature. Oils are less temperature sensitive than they used to be. It's the effect on the oil's function we're interested and you'll have installed the pressure gauge to measure that more directly. Oil temperature is related to coolant temperature. The exception being if you had a sudden increase in friction - it's doubtful the temperature of the sump would react to that quick enough. I suppose it might be a means of monitoring the transmission.
#12 Midas Mk1
Midas Mk1
  • 5,775 posts
  • Local Club: S.U.N.M.C
Posted 26 May 2017 - 10:45 AM
Im very interested to see if you manage to squeeze the sandwich stat and filter in place.
Doing l2b last week ive done 600 miles of motorway driving, and my oil pressure dropped 20psi when hot, which is making me think a cooler could be needed. I have two oil coolers ready, just want a stat so that it doesnt have any adverse effects.
#13 mina08
mina08
  • 255 posts
Posted 26 May 2017 - 01:52 PM
Mechanical oil pressure gauge and an electric oil temp gauge
#14 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 May 2017 - 06:52 PM
This thread suggests it os possible : http://www.theminifo...ler-thermostat/
#15 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Already have a mechanical oil pressure gauge fitted.
