Rear Handbrake Quadrants
13 replies to this topic
#1 vivalamini
vivalamini
  • 40 posts
Posted 24 May 2017 - 07:38 AM
Im rebuilding my rear subframe at the moment and I'm getting conflicting information around the right way to fit the split pin and clevis pin for the rear handbrake quadrants.
Is the clevis pin supposed to be dropped through from the top with the split pin and washer on bottom (as per Minispares parts drawing)
Or pushed through from the bottom with the split pin and washer on top???
Also the top hat bush that goes on the front trunnion, I've come to the conclusion it has to be fitted with the larger diameter end facing outwards? I.E. pressed up against the end with the 2 little holes on it.
Any help would be great. Thanks 👍🏻
#2 Steve220
Steve220
  • 4,990 posts
  • Local Club: BMC
Posted 24 May 2017 - 03:54 PM
From the bottom and washer at the top with clevis pin.
#3 Rorf
Rorf
  • 866 posts
Posted 24 May 2017 - 05:34 PM
Picture says a thousand words
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 24 May 2017 - 05:48 PM
Handbrake clevis pin goes thru from the top on dry suspensions.
Useful diagrams on Somerfird mini
Handbrake details here http://www.somerford...page=page&id=61
Rear subframe bush details here http://www.somerford...page=page&id=68
#5 MikeRotherham
MikeRotherham
  • 973 posts
Posted 24 May 2017 - 09:02 PM
The Rover manual shows the trunnion top hat bush with the narrow end pointing outwards and this was how mine was when I stripped it down
The rear brake cable quadrant spit pin and washer were on the top of the radius arm as per the photos above
Edited by MikeRotherham, 25 May 2017 - 06:31 AM.
#6 vivalamini
vivalamini
  • 40 posts
Posted 24 May 2017 - 10:43 PM
Thanks for the help everyone!
#7 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 25 May 2017 - 04:36 AM
I fit mine as per the picture above (clevis pin slides in from the bottom). That way when you have to remove it in future - and you will! - you don't have to remove the whole arm to get it out.
#8 SolarB
SolarB
  • 1,385 posts
Posted 25 May 2017 - 11:26 AM
Yep, insert from the underside and save yourself some grief in the future.
#9 tiger99
tiger99
  • 8,584 posts
Posted 25 May 2017 - 11:35 AM
I am wondering if using an R clip instead of a split pin might inspire you to take it apart once a year for cleaning and greasing? What do you think?
#10 SolarB
SolarB
  • 1,385 posts
Posted 25 May 2017 - 03:59 PM
Yep, an R clip work well and that's what I did with mine. Despite a thorough greasing when assembled one quadrant locked up a while ago. Took 10 minutes to remove and re-grease.
#11 Milton
Milton
  • 54 posts
  • Local Club: what no brakes
Posted 02 November 2017 - 04:33 PM
Sorry to hijack this post but I too have rebuilt my radius arms and have a question regarding which way round the quadrant goes. If you look at the quadrant one arc is longer than the other measuring from the lock pin on the handbrake cable. So should the longer arc be on the cable going to the drum or the cable going to the centre of the car.
Many thanks
Dave
#12 Spider
  • 14,635 posts
Posted 02 November 2017 - 06:32 PM
Longer Arc towards the Drum.
When fitted the other - incorrect - way, the arc will foul on the casting for the knuckle joint.
#13 carbon
carbon
  • 2,590 posts
Posted 02 November 2017 - 08:00 PM
As pointed out by Moke Spider, if you put the quadrants on the wrong way the rear brakes give really weak handbrake = MOT fail.
I had this problem a couple of years back, took me a while to work out what was wrong...
#14 Milton
Milton
  • 54 posts
Posted 03 November 2017 - 08:08 AM
Thanks Guys, 50/50 which way I put them on and guess what I did. Easy job to swap them around. Thanks for the advice
