Capillary Gauge Repair
Mat
, May 19 2017 07:51 PM
6 replies to this topic
Posted 19 May 2017 - 07:51 PM
I have a Smiths water temperature gauge on which the capillary bulb has split, around the solder. Obviously, all the ethanol has left the building; does anyone know of anywhere that could repair this and refill the ethanol?
Posted 19 May 2017 - 09:15 PM
Speedy Cables is one that springs to mind.
Here's a list of a few others;-
http://oldcarservice...rument-repairs/
Posted 20 May 2017 - 05:38 AM
Lovely, ta. Think I'll have a go myself first, but they'll be good back-up!
Posted 20 May 2017 - 09:26 AM
Mat,
If you're going to try and refill a capillary 0-110 water temp gauge then use di-ethyl ether. Ethanol won't give correct temp readings.
But not easy to do.
Posted 20 May 2017 - 02:28 PM
If using diethyl ether, please observe ALL required safety precautions. It is highly explosive when mixed with air, and things like operating a light switch, picking up the phone, or even electrostatic sparking generated by the carpet can set it off. Think petrol, only 100 times more sensitive.
For health and safety reasons I would be surprised if temperature gauges made since about 1980 would have contained anything as dangerous, but I may be wrong, if they had elaborate safety precautions in the factory. I would suggest that it is really not something to mess with at home unless you are fully trained in handling the stuff. A professional job will be much cheaper than the possible damage to lives and property.
I am sure that my old Rover P4 used alcohol in its temperature gauge. Every other car I have owned was electronic.
Posted 20 May 2017 - 03:30 PM
Carbon,
I should have written di-ethyl ether; I looked into it a long while ago and could only remember ethanol! Thanks.
Tiger99,
Having looked at it this afternoon, I think you are probably right. I'll stash the gauge for now, I imagine a replacement will be easier and cheaper overall. Thank you!
Tiger99,
