Posted 12 May 2017 - 04:34 PM
good year of engine as it will have the mems3 management, there isn't much you can take from a mgf as it's all the wrong way round unless your going rear engined I would take the whole wiring loom gear box and shafts, then you will need to get a gearlinkage from another mg/rover making sure it has the same gearbox either r65 or pg1 the pg1 gearbox is said to be the stronger of the two and has much more gear choices to play around with then for a subframe if your good with a welder make your own if not look at the allspeed subframe. Hope this helps
