Posted 12 May 2017 - 10:43 AM
AlexMozza, you are totally correct. I keep telling people that but no-one seems to believe me. The way around it is the two person technique, one presses the pedal, the other loosens and then nips up the nipple with the pedal held down. Do that on each stroke and the air can't come back in.
The better way used to be a product called ABV which stands for Automatic Bleed Valve. I used them successfully on various cars including Minis. They were like a normal nipple except that the conical sealing end was fixed to a thin shaft passing up the bleed passage to steady it, with a small spring to hold it down. When screwed in tight it was held against its seating like a normal nipple and made a good seal. When loosened about one turn, it became a one way valve, fluid and air could come out but nothing would go back in. Loosen first nipple, pump pedal a few times, tighten, top up reservoir, move on to second nipple... Job done in less than 5 minutes. Why are they not made any more?
There is a more complex product from the USA where the valve is internal in the body of the nipple and there is a seal for the thread. Should do the same job, but not so elegant.
spiguy, I have often wondered about plumbing in bleed nipples on both lines at the master cylinder. That should do what you describe, but would be less messy. What do you think?
