Joining Two 2" Exhaust Pipes - Which Method Is Best
7 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 May 2017 - 07:12 PM
I am fitting a new 2" exhaust to my existing 2" LCB. Which is the stingiest / best
I have a couple of options.
1 -  butt the ends together and use this type of joiner (it has a couple of layers of sheet which tighten)
Screen%20Shot%202017-05-11%20at%2021.04.
2 - butt the ends together and use this type of joiner with two suitable clamps
Screen%20Shot%202017-05-11%20at%2021.05.
3 - use a joiner where one half goes over one 2" pipe and the other end of the joiner is inserted into the other end.
#2 minimans
minimans
  • 411 posts
Posted 11 May 2017 - 08:05 PM
Option 3 is the winner! Or if you have enough length you can get an exhaust shop to expand one of the pipes to make it a slip fit over the other, less joint's to leak that way.
#3 mini13
mini13
  • 3,810 posts
Posted 11 May 2017 - 08:28 PM
that first type of jpint is actualy pretty good, they are used a fair amount on VAG stuff
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 May 2017 - 09:04 PM
Option one for me!
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 May 2017 - 09:25 PM
Indeed I have one on my Audi
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 11 May 2017 - 09:28 PM
Option one every time. Makes life so much easier when removing the exhaust in the future if like me you need to often :D
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 May 2017 - 09:31 PM
I will pick up an "option 1" tomorrow.
#8 nicklouse
  • 18,583 posts
Posted 11 May 2017 - 09:43 PM
My only comment is don't go for those clamps.
Get the ones that clamp the whole way round as they don't dent or put a ridge in the pipes making them hard to seperate or re assemble.
There is a forth option find a workshop that can open up the rear pipe so it will slide over the forward one.
Not the hand tools you can buy on eBay are not man enough to do it. But will take dents etc out of a previously round pipe.
