Real Slow Turner Over And Just Gets Slower And Won't Start
Posted 08 May 2017 - 08:39 PM
Posted 08 May 2017 - 09:07 PM
I had the same issue but had no earth.
Added 1earth lead from engine to bulkhead of car now good as gold.
Posted 08 May 2017 - 09:09 PM
Posted 08 May 2017 - 09:20 PM
Posted 08 May 2017 - 10:09 PM
Could even be the starter drawing too much current. Front bush has a habit of wearing out and allowing armature to rub on field coils causing too much drag. Check current draw with ammeter.
Posted 09 May 2017 - 11:30 AM
Hi George, I've just bought a 1981 Mini for restoration and my first task at the weekend was to get the engine running. The car didn't come with a battery so I used jump leads to connect a battery I had lying around. Like you the car turned over really slowly and then not at all so I assumed the battery wasn't up to the job. I changed it but the problem was the same.
I then decided to connect the battery directly to the starter solenoid so that I could be sure it wasn't the battery or starter motor. When I did the engine turned over perfectly and I was able to get it started.
I have attached a picture of the connections I made but I'm sure yours will be different, assuming your body is negative then you need to connect the negative to the engine and the positive to the solenoid, if you get the solenoid connection the wrong way around the starter will come on without turning the key so just connect it to the other post.
Good luck.
Edited by neilw, 09 May 2017 - 11:48 AM.
Posted 09 May 2017 - 03:54 PM
Halfords or any of the kit car suppliers or car electrical suppliers will have all the bits that you need, and they are not all that expensive.
Check the earth strap in the boot too, and the floor where it is bolted. It would do no harm to take it apart, clean back to bare metal, bolt up tightly and apply Waxoyl.
