Motor Bike Carbs On A Mini?
21 replies to this topic
#16 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 09 May 2017 - 12:30 AM
I've heard of a few in Australia with big single Mikuni motorbike carbs
http://www.mikunioz....hsr-45-mm-carb/
#17 Rob Jones
Rob Jones
  • 40 posts
  • Local Club: North Wales Car Club
Posted 09 May 2017 - 08:01 AM
http://www.theminifo...dpost&p=2131479
This is what I did a few years ago!
#18 Udo
Udo
  • 1,670 posts
Posted 09 May 2017 - 08:56 AM
http://www.theminifo...showtopic=39131
Same here but even longer ago!
Just for comparission I changed from a correctly dyno tuned weber DCOE45 to the above set up
Outcome was 1000 less rpm to get the same power output however the gains were in the power delivery and the vastly lower amount of fuel used compared with the Weber
#19 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 09 May 2017 - 09:08 AM
Super cheap to purchase and also much cheaper to set-up.  The main jet is drilled in millimetres, so a 140 jet on a Mikuni  is 1.4mm, all you need is a cheap set of small metric drills and you can change you jetting, if it's too big you just solder it up and redrill it.
#20 Udo
Udo
  • 1,670 posts
Posted 09 May 2017 - 12:27 PM
Exactly
Tuner had a set of jets, swapped out until correct one found then mine adjusted to suit, and he kept his "set". There was something about blocking some air jets also but cant remember what exactly
#21 hhhh
hhhh
  • 422 posts
Posted 09 May 2017 - 01:42 PM
Well, yes and no. A jet is more than just a hole. Any imperfections after drilling on the entry or exit can affect flow more than you think.
#22 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 09 May 2017 - 01:53 PM
I've had a pair 38mm flat side, semi-downdraught Mikunis off a TRX850 on the shelf for a while.  I've been mulling over fitting them.  must get round to it.
