With a side -mounted radiator the big risk with an electric fan is fan motor failure. A side mounted engine requires the fan to run 100% of the time and electric fan motors are not intended to have a 100% duty-cycle.
Remember, electric power is not 'free'. If a fan pushes the same amount of air through the radiator it will need similar power. That power needs to come from the engine, either from the alternator or from the water pump shaft. An electric motor might be slightly more efficient, but is it worth the risk on a road car? On a short race or hill-climb the very small power increase might save a few 1/10ths of a second, everything else being equal.
