Hey All,
On the drive to work this morning, my 1380 was a little spluttery and backfired through the carb pulling out of the 50 average zone, having spent about 20 mins at those revs. Cleared once rev’d abit on the b roads
Got me thinking, and doing a search on here I’ve confused myself regarding ht lead / plug combinations.
Had it dyno’d on resistor 6’s, but was strongly advised for 7’s due to the high end spec of the engine, (worked 1380).
As I run an aldon yellow with ignitor, lucas sports coil etc, I’ve always thought I needed resistor plugs, so have been using the BPR7’s, as recommend when I had the carb and timing set on the rollers last year.
I had the ignitor fail last year, needing replacement.
One of my magnecor super dooper leads snapped last week, so I’ve replaced them with these
http://minispares.co...|Back to search
Now doing a search, Im confused as some say its fine running these type ht leads, others say otherwise.
It’s always been abit rough and spluttery when cold, but runs ok when warm! Do I need to go the resistor-less plugs (BP7’s)? Is there currently too much resistance perhaps?
Edited by Midas Mk1, 28 April 2017 - 11:03 AM.
