Gearbox Idler Gear Bearing Replacement
8 replies to this topic
#1 Midas Mk1
Midas Mk1
  • 5,776 posts
  • Local Club: S.U.N.M.C
Posted 15 April 2017 - 12:59 PM
Hi all,
Just re shimming my idler gears, and found my gearbox idler gear bearing to be shagged. Got a new one here to fit, just how do you get the old one out? Currently the engine and box is attached together. Done a a search but not come up with much, and really looking to do it ASAP.
Any help greatly appreciated
Sam
#2 RooBoonix
RooBoonix
  • 1,224 posts
Posted 15 April 2017 - 01:06 PM
Ideally use a bearing puller. Pull/bend out the rollers and cage then use the puller to pull the outer race out.
I didn't have one, but my engine and gearbox were split so I wacked it out from behind using a socket. To get the one out of my transfer case I used a piece of threaded bar and washer and welded the washer to the bearing race. Pullers can be gotten relatively cheap or your local garage/machine shop will probably get it out in minutes (whilst you wait) with a proper puller.
I wacked the new one using a plastic dead blow hammer.
Hope that helps,
Cam.
#3 johnR
johnR
  • 2,297 posts
Posted 15 April 2017 - 01:07 PM
Bearings that can't be knocked through need to be pulled out with a slide hammer and blind bearing puller - cheapish sets of pullers are available on Ebay.
Edited by johnR, 15 April 2017 - 01:08 PM.
#4 Midas Mk1
Midas Mk1
  • 5,776 posts
Posted 15 April 2017 - 01:23 PM
Thanks guys! Machine marr don't have a blind puller small enough, so think I'm gonna have to split the box and use the socket method! Gonna be a long day I think aha
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 15 April 2017 - 01:27 PM
I did this back along: you need just the right size washer that you can file the sides off to fit in to the bearing with the rollers removed. the problem with welding it that it can crack the case as the bearing expands in the hole.
then we moved onto the other idler bearing, this is how we did it:
Knocked out the rollers and cage by sticking screwdriver between the cage and bearing body.(imagine it's in the casing)
Then got a longish bolt, a thick washer which we cut the sides off to the size of the holw
it can then be put on the bolt and slid into the the bearing.
then get a plate/bar to got over the caseing and wind the nut with a few washers onto it, you may need to put a spacer in like my pic.
#6 RooBoonix
RooBoonix
  • 1,224 posts
Posted 15 April 2017 - 01:28 PM
There is another method, using a washer with the sides ground off...........
Just as I was typing the man himself replied ^^^
#7 limby2000
limby2000
  • 366 posts
Posted 15 April 2017 - 05:52 PM
Wow, the washer idea, so simple its fantastic. I bought a cheap Bergen blind bearing puller when i done my top arms and radius arms. It worked for a total of 1x bearing before breaking. I eventually used a Dremel with a fine tip and cut a slot, carefully.
#8 Midas Mk1
Midas Mk1
  • 5,776 posts
Posted 15 April 2017 - 06:23 PM
All sorted! Thanks guys! Really appreciate your speedy response, managed to get it split and back together today, ready for refitting tomorrow! :)
#9 mini13
mini13
  • 3,810 posts
Posted 17 April 2017 - 09:47 PM
Another trick for getting a bearing out of a blind hole is to fill it with grease and put a tight fitting Shaft in and give it a good whack, the grease should push it out.
