hi,
i race a classic mini in autograss class 4 and have been having trouble with the crown wheel stripping teeth, the gearbox is all new apart from the case, gearbox spec:
gearbox case dam 5626 3 bolt bearing retainer
swiftune roller drop gears straight cut ratio, 1:087
MED race dog box box gearset
swiftune Tran-x LSD diff
swiftune Lsd 4.7 cwp
all bearings new and quility RHP brand
the crownwheel strips teeth when I set of the startline, 1st gear, drop the clutch at no less than 5000rmp otherwise engine boggs and drops of the cam.
the engine is 1130cc, makes around 110hp at the flywheel, the engine is fitted with lightwieght reduced diameter flywheel sold by lynx ae, so reves really quick and to around 8000rpm (engine is all steel crank and rods )
the crown wheel issue has happend twice now using two different makes (MED and swiftune)
so I have just rebuilt the gearbox again and this time I have fitted a pinion support, to eliminate the pinion climbing up the crownwheel and going out of mesh, I have change the engine mounts from solid to rubber to eliminate any extra stress or flex though the gearbox as the engine is mounted in a spaceframe not a mini subframe, I have ground out all the casing casting flash marks in the gearbox case to make it smooth to eliminate a potential crack starting.
engine is now back in the car but has not been raced since gearbox rebuild, any help will appreciated, as I don't really what this issue to happen again as I don't know what else I can do to strengthen or de stress the gearbox?
can any body please advise if they have had this issue before and how they solved it please?
