This engine is a 1275 Austin america with Cooper S head with an early maybe 850 transmission housing. it has Kent 266 cam and straight cut new gears. When i took it home the rocker vent hose was vented to the HIF6 carb which is why I didn't notice the little smoke. As soon as I noticed, I took action by creating a vent from the block's mechanical fuel pump blanking plate to an oil catch can and i rerouted the rocker cover vent to the same catch can and that's when I noticed the little smoke coming out from the air filter of the Moroso can. the smoke appears to just linger and not puffing/ chugging together with the sound of the engine like how you see worse scenarios on youtube. Is there any chance that this engine is still in break in period and i should just change oil and let the rings sit? Or am I doomed and just expect to pull the engine for another rebuild?
update:
was dieseling and running rich which i now corrected and plugged the carb where it used to be vented.
click on pic
https://farm4.static...a90c51b1d_h.jpg
https://farm3.static...409000313_h.jpg
Edited by Mk1cooper, 13 April 2017 - 10:59 PM.
