Tubing For Vacuum Gauge
6 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 12 April 2017 - 10:39 AM
Hi;
What type of tubing should I use for a vacuum gauge? Would windscreen washer bottle piping be ok or does it need to be better?
#2 tiger99
tiger99
  • 8,584 posts
Posted 12 April 2017 - 11:45 AM
That will be ok if small enough diameter. Too large and it would collapse under vacuum. Easy to check. The hard black stuff sometimes used on the vacuum advance pipe to the distributor is also ok if it fits. Depends on what diameter you need.
If in doubt, try some of the Kit Car parts suppliers who are likely to have proper vacuum hose, but you usually need that only for the brake servo.
#3 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 12 April 2017 - 11:48 AM
Silicone hose should be fine
#4 richmondclassicsnorthwales
  • 942 posts
Posted 01 May 2017 - 05:11 AM
Use the line for oil pressure gauges from MiniSpares. It is the plasic line and has all the fittings on it too for your gauge,
#5 Jml643
Jml643
    Just On Tickover
  • 8 posts
Posted 01 May 2017 - 09:46 AM
Most turbo diesel cars have loads of small bore vacuum tubing running round the engine bay so should be readily available from a decent auto factor, or car breaker if you're stuck. I have used washer hose in the distant past but it's probably not ideal.
#6 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 01 May 2017 - 10:42 PM
My vacuum gauge has a push-fit for hose not screw-on (Smiths Classic). Small bore but thickish wall hose.
#7 RooBoonix
RooBoonix
  • 1,224 posts
Posted 01 May 2017 - 10:54 PM
I use 3mm silicone vacuum hose from eBay.. pretty thick walled and seems to cope ok under the vacuum created. However, in my SPi the gauge would go mental at tickover so I cut up a cigarette filter and shoved it down the vacuum line at the gauge end and now it's steady at any throttle position.
Edited by RooBoonix, 01 May 2017 - 10:54 PM.
