Don't forget you need to make sure the injectors are not too large. One of the biggest problems we found with the larger injectors is, they are open for a shorter time and therefore are more difficult to control especially at high revs. A smaller injector opens for longer and the fueling measure is easier for the injector to control and therefore more accurate. It may sound counter intuitive but its down to the time taken opening and closing the injector compared to the open time of the injector. The other area we looked at was the spray pattern. Not all injectors spray in a conical pattern and by rotating the injectors through 90 degrees with gained another 4 bhp.
Which Ecu Do People Recommend?
#16
Posted 11 April 2017 - 10:04 AM
#17
Posted 16 April 2017 - 01:09 AM
Smoother running, mappable, more power, better emissions!
Mappable, I agree. Smoother running and better emissions than a stock MPI injection system? From a wet manifold injection system? That's a hard claim to believe (especially about better emissions.)
Now if it's a comparison with a modified MPI injection system, then all the claims make sense to me. Any current modification to the MPI injection system retaining the factory ECU will be something of a bodge and could well be (probably likely to be) inferior to the SC unit in smoothness and even emissions.
#18
Posted 17 April 2017 - 09:43 AM
#19
Posted 17 April 2017 - 04:36 PM
