New Wings -Seam Sealing?
Posted 02 April 2017 - 08:45 AM
Posted 02 April 2017 - 10:27 AM
I use a brushable seam sealer on the seams behind in the wheel arch and normal gun sealer on the outside.
It's a good idea to mask of the external seams prior then you can gun the sealer in, wipe to shape with a finger or cloth soaked in panel wipe and then peel the tape off
Ben
Posted 02 April 2017 - 04:33 PM
Posted 02 April 2017 - 04:43 PM
Should the bonnet lip edge also be done?
Yes as that is a water trap.
Posted 07 April 2017 - 09:18 PM
Hi Guys
Sorry to jump in on this thread,
Do you seam seal
- before etch and primer
- between etch and primer
- after etch and primer
Also any recommendations on which to use preferably not brush on.
Thanks in advance
Josh
Posted 07 April 2017 - 09:41 PM
I seam seal after Epoxy primer. I use Aviation sealant which has anti corrosion inhibitor as part of its mix.
Posted 07 April 2017 - 10:25 PM
Always have a primer on before applying the seam sealer.
It is also unnecessary to primer over the seam sealer.
I always make sure that the seam sealing is the last thing i do before applying colour so the car would be primed, flatted and then sealed.
Posted 10 April 2017 - 04:59 PM
