Mamba Wheel Nuts
9 replies to this topic
#1 dossy
dossy
  • 271 posts
  • Local Club: Suggestions for North Yorks?
Posted 27 March 2017 - 02:15 PM
another special mong moment.... didn't realise mamba wheels has special wheel nuts...
anyone got a full set of mamba wheel nuts for sale?
#2 r.tec
r.tec
  • 183 posts
  • Local Club: SfG Schoenau
Posted 25 December 2024 - 04:17 PM
First of all, a Merry Christmas to everybody.
Apologies for opening an old thread but I felt that the title fits perfectly.
A few days ago I received my order from MiniSport containing four Mambas 6x10.
I always thought that the Mambas utilized the same wheel nuts like the Revolutions but by opening the JBW labelled boxes I had to learn that there are 60° taper nuts included.
But as you can see on the photos the nuts reach far too less out of the centre to have sufficient grip for the fastening nut which has a diameter of 24 mm and is slimline, the smallest I could find.
The hole is only 21 mm so that won't work physically alone. I thought of buying a hex rod with 19mm AF and make longer nuts on my lathe but the best steel I could find is C45 which has a max. tensile strengh of around 500 MPa (N/mm²).
Any advice would be appreciated.
Attached File  2024-12-25 Mamba 6x10 (1).jpg   99.83K   4 downloads Attached File  2024-12-25 Mamba 6x10 (2).jpg   81.1K   4 downloads
Attached File  2024-12-25 Mamba 6x10 (3).jpg   88.46K   3 downloads Attached File  2024-12-25 Mamba 6x10 (5).jpg   65.71K   1 downloads
#3 nicklouse
  • 18,556 posts
Posted 25 December 2024 - 07:42 PM
Talk to the supplier.
have they even supplied the correct nuts?
https://johnbrownwhe...amba-wheels-TN1
Edited by nicklouse, 25 December 2024 - 07:45 PM.
#4 r.tec
r.tec
  • 183 posts
Posted 26 December 2024 - 07:35 AM
No, supplied were these : https://johnbrownwhe...er-wheel-nut-N1 in black.
Are the correct ones hexagone socket?
#5 nicklouse
  • 18,556 posts
Posted 26 December 2024 - 08:55 AM
Not according to their website.
but I would not expect the seller to know that.
#6 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 26 December 2024 - 04:12 PM
Wrong nuts. Look at the photos on jbw website, the repro mambas use an inverted style nut
#7 r.tec
r.tec
  • 183 posts
Posted 27 December 2024 - 10:03 AM
Yes, I know now but the Minisport chaps should have known it before me! https://www.minispar...ds-mamba-wheels
by the way. Why change the fastening to a worse one when the former worked perfectly well? For me this is an example of bad engineering. Perhaps sleeve-type nuts are more expensive to manufacture than taper nuts? Do not accept this.
Thank you all for enlightening me!
#8 nicklouse
  • 18,556 posts
Posted 27 December 2024 - 10:25 AM
There is one word there that answers your question. I would also suggest the wheel makers had to find a way to change the original design?  Yes the sleve nuts are not cheep to produce.
#9 r.tec
r.tec
  • 183 posts
Posted 27 December 2024 - 12:34 PM
Again me, hope I do not bother you.
In my vast selection of this and that I found some 14mm AF 3/8-24 wheel nuts and a long sleeve nut goes over it without problem.
I would like to know your opinions and if you think the nuts are up to the job.
Attached File  2024-12-27 (2).jpg   109.32K   1 downloads  Attached File  2024-12-27 (3).jpg   106.28K   0 downloads
Attached File  2024-12-27 (4).jpg   91.19K   0 downloads
#10 r.tec
r.tec
  • 183 posts
Posted 21 January 2025 - 09:48 AM
Hi, MiniSport has just sent the missing Allen key wheel nuts for the Mambas.
The Allen AF is 12mm with an Adapter to fasten them with 17 AND 19mm ordinary nuts.
Attached File  2025-01-21 (1).JPG   66.11K   0 downloads
Attached File  2025-01-21 (2).JPG   44.66K   0 downloads
Attached File  2025-01-21 (3).JPG   39.31K   0 downloads
