The Red One
137 replies to this topic
#106 Mito
Mito
  • 406 posts
Posted 17 April 2022 - 06:27 PM
Last weekend I painted the petrol tank, ticket cover, the servo, and a few other parts gloss black.
Attached File  PXL_20220410_133355436.jpg   55.41K   5 downloads
I also made a start installing the new facet pump.
Attached File  PXL_20220411_163028096.jpg   41.53K   8 downloads
I need to make a bracket for it, so I've left it there for now.
This weekend the manifolds have gone on and the carb, as well as some ignition related components.
Attached File  PXL_20220417_145122902.jpg   102.96K   8 downloads
As the engine is all together, and the wiring harnesses are connected up, and the oil pressure was good, it was time to attempt to start it. After messing around with the spark plug leads for a while, I didn't realise the distributor goes anti clockwise, she started!
Whilst this was going on, my brother sprayed the bonnet.
Attached File  PXL_20220417_151528727.jpg   67.56K   5 downloads
#107 colinf1
colinf1
  • 968 posts
Posted 17 April 2022 - 09:46 PM
Great progress! Looks like its coming together quiet nicely
#108 Mito
Mito
  • 406 posts
Posted 27 April 2022 - 04:30 AM
Lower dash rail and switches installed.
Attached File  PXL_20220418_102146446.jpg   75.55K   3 downloads
Added some econoseal connectors to the front indicators as the bullet connectors were part it.
Attached File  PXL_20220418_160642022.jpg   70.39K   0 downloads
Fitted the brake servo and pipes.
Attached File  PXL_20220419_194409009.jpg   52.53K   0 downloads
Attached File  PXL_20220419_194416230.jpg   45.76K   0 downloads
Fitted the rear screen. As this was the first screen if fitted, it was an absolute pain to fit until I realised I only needed to push the screen close enough to the seal to feed it over and not tight up to the seal.
Attached File  PXL_20220426_200858950.jpg   60K   0 downloads
Upper dash rail fitted. There's a little red led that is unused, presumably for an old alarm, that I'm going to use as a warning light for the inertia switch.
Attached File  PXL_20220426_200838089.jpg   70.83K   2 downloads
Last night, the windscreen was fitted. This was much easier than the rear, following the lessons learnt.
Attached File  PXL_20220426_200820535.jpg   83.11K   2 downloads
#109 Mini_MikeG
Mini_MikeG
    Just On Tickover
  • 6 posts
Posted 27 April 2022 - 09:47 AM
I've only just seen this project. Good work, your at the exciting stage now! I've got a long way to go with mine still
#110 Mito
Mito
  • 406 posts
Posted 15 May 2022 - 11:57 AM
I'll add the rest of the updates later but suffice to say, it passed its MOT and made it on the London to Brighton run
Attached File  PXL_20220515_104241452.jpg   95.76K   2 downloads
#111 slidehammer
slidehammer
  • 1,151 posts
  • Local Club: LSMOC
Posted 15 May 2022 - 07:00 PM
Good work,, looking really smart. I was there what was the que like onto Madeira Drive?
#112 Mito
Mito
  • 406 posts
Posted 15 May 2022 - 09:27 PM
we got there about 10.30 and I think we were queuing for about 30 mins, so not too bad.
Edited by Mito, 15 May 2022 - 09:28 PM.
#113 slidehammer
slidehammer
  • 1,151 posts
  • Local Club: LSMOC
Posted 16 May 2022 - 06:44 PM
we had to que for 2 hours which was a pain.
#114 Hpal
Hpal
  • 96 posts
Posted 17 May 2022 - 11:42 PM
Congratulations! You had it going by May as you had hoped :)
#115 Mito
Mito
  • 406 posts
Posted 13 August 2023 - 07:25 PM
It looks like in my rush to get the car ready for the London to Brighton run in 2022, I didn't take many pictures.
A couple of the interior (actually the cat making himself at home)
Attached File  PXL_20220611_121523088.jpeg   41.58K   1 downloads
Attached File  PXL_20220513_113844076.jpeg   64.03K   5 downloads
Engine bay
Attached File  PXL_20220813_145203414.jpeg   92.28K   8 downloads
Attached File  PXL_20220813_145159669.jpeg   70.25K   6 downloads
Moved into its new home
Attached File  PXL_20230324_172622024.jpeg   64.85K   3 downloads
Fitted works lamp bar
Attached File  PXL_20230424_152825743.jpeg   91.92K   1 downloads
London to Brighton 2023 (the finale :()
Arrived at Cheam
Attached File  PXL_20230520_145441254.jpeg   82.86K   1 downloads
In the line up
Attached File  PXL_20230520_181558884.jpeg   99.63K   0 downloads
Ready to go
Attached File  PXL_20230521_064731375.jpeg   128.27K   1 downloads
On the way to Brighton
Attached File  FB_IMG_1684791325140.jpeg   55.93K   0 downloads
Madeira Drive
Attached File  FB_IMG_1684790904442.jpeg   50.61K   0 downloads
Attached File  PXL_20230521_111400414.jpeg   104.28K   0 downloads
Hit 70k miles on the way home
Attached File  PXL_20230521_155421566.jpeg   41.31K   0 downloads
2023 The Breakdown - East Coast Run
RAC Attempted Roadside Repair
Attached File  PXL_20230611_135154570.jpeg   97.69K   1 downloads
Unfortunately it could not be repaired at the roadside and had to be towed home. End of this run for this year. We were only about 1 mile from our destination (Sewerby).
Attached File  PXL_20230611_161619032.jpeg   103.55K   1 downloads
The damage
Attached File  PXL_20230619_154412634.jpeg   51.37K   1 downloads
Attached File  PXL_20230619_154425395.jpeg   78.06K   0 downloads
The fly wheel pulley bolt had fallen out and could be heard rattling around between the pully wheel and the engine mount. The woodruff key channel has been damaged, so I decided to buy a replacement.
The replacement...
Attached File  PXL_20230812_145203431.jpeg   41.21K   0 downloads
Think I'll paint it before I fit it to the car, so had a go with my new shot blasting cabinet,
Attached File  PXL_20230812_150142640.jpeg   33.38K   0 downloads
I'm going to put a duplex timing chain on it since I have to remove the timing chain to replace the woodruff key that has sheared in half.
#116 Designer
Designer
  • 502 posts
  • Local Club: 8 Iron
Posted 14 August 2023 - 06:38 AM
I see from your third picture that you engine does not have a CAT so I hope it is ULEZ compliant. :D  :D  :D  :D  :D
#117 Mito
Mito
  • 406 posts
Posted 14 August 2023 - 05:28 PM
nope. I don't live in London though and there are no ulez zones currently that I'll be frequenting.
8 years to historic status!
#118 stuart bowes
stuart bowes
  • 1,891 posts
Posted 15 August 2023 - 08:27 AM
I'm sure I sure a cat in the earlier pics though did you remove it
#119 Mito
Mito
  • 406 posts
Posted 15 August 2023 - 06:37 PM
yeah, it started to get a bit noisy
#120 johnR
johnR
  • 2,288 posts
Posted 21 August 2023 - 11:34 AM
painting your radiator shroud would improve your engine bay no end or are you going for the patinated look? :)
