The Red One
137 replies to this topic
#91 Mito
Mito
  • 406 posts
Posted 16 January 2022 - 06:29 PM
A few photos of my handy work.
Edited by Mito, 16 January 2022 - 06:34 PM.
#92 Mito
Mito
  • 406 posts
Posted 16 January 2022 - 06:31 PM
duplicate post
Edited by Mito, 16 January 2022 - 06:32 PM.
#93 Mito
Mito
  • 406 posts
Posted 09 February 2022 - 08:27 PM
While I'm waiting for the suspension parts and wheels to come back from the powder coaters, I thought I would make a start refurbing some of the other parts.
I started with removing the heater matrix from the heater.
Attached File  Photo Resizer 2022_02_09_08_13_36.jpg   48.49K   1 downloads
It looks like this may have had a bit of a leak, which was probably contributing to the water in the passenger foot well and the rusty floor pan.
I've now replaced this with a new heater matrix but it didn't come with any foam which I'm guessing is required to prevent it from rubbing on the sides of the case and rupturing or just making an annoying noise.
I stripped the clutch master cylinder and put it in some deox-c as the bottom bracket was quite rusty. Once it had been left, it was rinsed, polished and rebuilt.
Attached File  Photo Resizer 2022_02_09_08_13_30.jpg   46.19K   2 downloads
The tower bolts also had a bit of rust on them, so these went into the same deox-c bath. I've applied some acf-50 to them to help keep the rust at bay.
Attached File  Photo Resizer 2022_02_09_08_13_12.jpg   51.08K   3 downloads
I then heard that the London to Brighton run is on in May and now need to step things up a gear.
The head came off the engine so that I could see the extent of the work required. The gearbox was fine and the engine was running, albeit very rich, before it was taken out of the car. There is a lip in the bore, so time to strip it and re-work the block.
Attached File  Photo Resizer 2022_02_09_08_13_05.jpg   41.85K   5 downloads
Attached File  Photo Resizer 2022_02_09_08_12_57.jpg   50.14K   2 downloads
Carbony! I'll strip the engine next month before I take it in to be bored and deck refaced.
On with the carb. I've fully stripped the carb and left it in some surfex overnight.
Attached File  Photo Resizer 2022_02_09_08_12_47.jpg   53.78K   4 downloads
Attached File  Photo Resizer 2022_02_09_08_12_02.jpg   65.61K   1 downloads
I'll carry on cleaning and rebuild it tomorrow.
#94 johnR
johnR
  • 2,288 posts
Posted 09 February 2022 - 10:33 PM
Deox C is great stuff isn't it? that's one grubby carb!
#95 Mito
Mito
  • 406 posts
Posted 09 February 2022 - 10:45 PM
Yeah, the only time it has failed to shift the rust is in an old petrol tank I have. I may give it another go at some point. It has been great on all of the other parts I've used it on though.
The carb is looking better already, just some stubborn bits that I thought might shift after an overnight soak. There's probably 30 years worth of dirt and grime on it in the pic.
#96 Mito
Mito
  • 406 posts
Posted 10 February 2022 - 05:13 PM
After an overnight soak in Surfex, the carb parts have come out pretty clean.
Main body
Attached File  Photo Resizer 2022_02_10_05_03_58.jpg   53.01K   1 downloads
Parts ready to be assembled.
Attached File  Photo Resizer 2022_02_10_05_03_51.jpg   97.96K   0 downloads
Fully rebuilt with new jet, gaskets, and a MiniSpares superflow float needle.
Attached File  Photo Resizer 2022_02_10_05_03_43.jpg   87.3K   1 downloads
It could do with a good polish, but it looks a lot better and cleaner than it was. Hopefully it won't over-fuel when it goes back on the engine.
The slave cylinder was also looking a bit crusty, so I disassembled it and put it in some deox-c.
Attached File  Photo Resizer 2022_02_10_05_03_29.jpg   113.98K   0 downloads
Attached File  Photo Resizer 2022_02_10_05_03_06.jpg   25.75K   1 downloads
It's come out looking like new, the only thing is I bought the wrong rebuild kit for it. Damn! So this will have to wait until the next parts run.
The re-assembled clutch master.
Attached File  Photo Resizer 2022_02_10_05_03_36.jpg   52.97K   1 downloads
#97 Mito
Mito
  • 406 posts
Posted 17 February 2022 - 06:20 PM
Back in 2017 when the car was taken off the road, it was running very rich and in addition to all of the body work issues also failed on emissions. It wasn't worth even a cursory look at this at the time.
CO 9.56%
HC 1418
I'm convinced that this was due to it over fuelling and that this was due to an issue with the carb, likely the float bowl overflowing as there was a very strong smell of petrol if you round the front windows down.
The float needle seat on the carb didn't have a washer under it, so possibly wasn't sealing and allowing the petrol to continue flowing?
As time is tight to get it back on the road for the London to Brighton run in May, I've decided to give the engine an ebay refurb, clean and paint, and then drop it in the car, and take it for MOT asap in April in the hope that it runs okay and passes. If it doesn't, then it will have to be rebuilt which I think will push me beyond my deadline.
So, new head gasket delivered today.
Attached File  Photo Resizer 2022_02_17_06_01_24.jpg   30.18K   0 downloads
This weekends plan...
  1. Collect parts from shot blasters
  2. Paint rear radius arms and a few other parts
  3. Assemble as much of the front and rear subframes as possible
#98 Mito
Mito
  • 406 posts
Posted 21 February 2022 - 08:01 PM
I didn't quite finish what I had planned for this weekend.
Picked up the refurbished alloy wheels. They're finished in metallic black.
Attached File  Photo Resizer 2022_02_21_07_45_18.jpg   62.56K   3 downloads
Sprayed a few of the suspension components that I had forgotten to take to the powder coaters in matt black
Tie bars, throttle pedal, servo bracket, front subframe mounts, and the plate behind the carb.
Attached File  Photo Resizer 2022_02_21_07_46_22.jpg   86.23K   1 downloads
Close ups
Attached File  Photo Resizer 2022_02_21_07_46_15.jpg   55.81K   0 downloads
Attached File  Photo Resizer 2022_02_21_07_46_07.jpg   59.44K   1 downloads
Attached File  Photo Resizer 2022_02_21_07_46_01.jpg   43.47K   1 downloads
Attached File  Photo Resizer 2022_02_21_07_45_53.jpg   36.58K   1 downloads
Attached File  Photo Resizer 2022_02_21_07_45_47.jpg   63.6K   0 downloads
The new donuts where in bare metal, so they were painted as well along with the rear radius arms.
Attached File  Photo Resizer 2022_02_21_07_46_31.jpg   89.68K   0 downloads
Attached File  Photo Resizer 2022_02_21_07_46_59.jpg   93.72K   0 downloads
Attached File  Photo Resizer 2022_02_21_07_46_45.jpg   48.3K   1 downloads
Attached File  Photo Resizer 2022_02_21_07_46_36.jpg   50.57K   1 downloads
All looking much better.
Picked up some more parts from the powder coaters, just the rear subframe to pick up now.
Attached File  Photo Resizer 2022_02_21_07_45_39.jpg   107.12K   1 downloads
#99 Mito
Mito
  • 406 posts
Posted 13 March 2022 - 10:20 PM
Another pic of the painted rear suspension parts.
Attached File  Photo Resizer 2022_03_13_10_11_56.jpg   57.76K   0 downloads
The rear subframe back from shot blasting and powder coating.
Attached File  Photo Resizer 2022_03_13_10_12_09.jpg   82.51K   0 downloads
During the assembly of the subframe, pushing the rear radius arm pin through its mounting hole, the bracket for the brake line became detached. It appears that the spot welds holding the bracket in place where not done properly.
Attached File  Photo Resizer 2022_03_13_10_09_15.jpg   70.12K   1 downloads
Attached File  Photo Resizer 2022_03_13_10_09_24.jpg   46.13K   0 downloads
I cleaned up the area and welded the bracket back on.
Attached File  Photo Resizer 2022_03_13_10_09_09.jpg   65.42K   0 downloads
The rear subframe is now pretty much assembled baring one brake line which I kinked, so I'm not quite ready to put it back on the car yet.
The front subframe is now assembled barring the hubs and brake calipers.
Attached File  Photo Resizer 2022_03_13_10_08_54.jpg   94.76K   0 downloads
Attached File  Photo Resizer 2022_03_13_10_09_00.jpg   55.93K   1 downloads
And now the subframe is back on the car.
Attached File  Photo Resizer 2022_03_13_10_08_39.jpg   75.52K   0 downloads
Attached File  Photo Resizer 2022_03_13_10_08_31.jpg   54.74K   0 downloads
Attached File  Photo Resizer 2022_03_13_10_08_10.jpg   69.72K   0 downloads
#100 Mito
Mito
  • 406 posts
Posted 18 March 2022 - 07:00 AM
Rebuilt the clutch slave cylinder.
Attached File  Photo Resizer 2022_03_18_06_50_17.jpg   39.59K   1 downloads
Built up one of the front hubs with new Timken bearings. I'm still waiting for the new ball joints to arrive.
Attached File  Photo Resizer 2022_03_18_06_49_58.jpg   91.37K   0 downloads
Finished off building the rear subframe and installed in the car.
Attached File  Photo Resizer 2022_03_18_06_50_06.jpg   46.65K   0 downloads
Started assembling the rear brakes.
Attached File  Photo Resizer 2022_03_18_06_49_50.jpg   74.41K   0 downloads
After this I put on the rear shocks. However, they don't extend far enough to be able to fit them to the wheel arch.
Then I rebuilt the brake calliper's with new seals and new bolts with Loctite 270. Bolts torqued to 60lbft. They have been shot blasted but have some surface rust on them, so just put them in a bath of Deox-C to remove it before paint.
Attached File  Photo Resizer 2022_03_18_06_49_30.jpg   62.43K   4 downloads
Edited by Mito, 18 March 2022 - 07:04 AM.
#101 Mito
Mito
  • 406 posts
Posted 30 March 2022 - 08:00 PM
The new "no shims" required ball joints arrived which meant the front hubs could be finished off.
Attached File  Photo Resizer 2022_03_30_08_53_27.jpg   55.16K   2 downloads
nice. Easy to fit as well, so this didn't take long at all.
Rear drums painted red and on the car.
Attached File  Photo Resizer 2022_03_30_08_53_21.jpg   50.68K   0 downloads
It has a steering wheel!
Attached File  Photo Resizer 2022_03_30_08_53_15.jpg   45.14K   0 downloads
Loosely assembled the front suspension ready for the wheels to be fitted. They'll have to come off again when the engine and drive shafts are being fitted, so thought I'd make my life a bit easier.
Attached File  Photo Resizer 2022_03_30_08_52_45.jpg   43.6K   0 downloads
Went to have fitted the new Yokohama A539's. Now on the car.
Attached File  Photo Resizer 2022_03_30_08_50_49.jpg   74.28K   1 downloads
Cleaned the engine and gave it a coat of yellow paint.
Attached File  Photo Resizer 2022_03_30_08_50_42.jpg   104.31K   0 downloads
Attached File  Photo Resizer 2022_03_30_08_50_36.jpg   98.08K   0 downloads
Getting there. 4 weeks remaining to get it road worthy.
#102 johnR
johnR
  • 2,288 posts
Posted 01 April 2022 - 06:55 PM
loads of time - if you spend every waking hour on it!
#103 Mito
Mito
  • 406 posts
Posted 03 April 2022 - 10:02 AM
it will be done
#104 johnR
johnR
  • 2,288 posts
Posted 03 April 2022 - 11:17 AM
I got my bodyshell back in June 2015 and it was ready to drive to Monte Carlo in the September, but I had been renovating parts while the welding was being done. it was the customised parts that took the time rather than just bolting on standard stuff.
#105 Mito
Mito
  • 406 posts
Posted 06 April 2022 - 08:02 PM
Engine painted using por15. So much for it only requiring one coat. This took 3 costs for it to cover.
Attached File  IMG-20220402-WA0000.jpg   40.86K   0 downloads
Dropped in the half engine.
Attached File  PXL_20220403_155117998.jpg   100.58K   0 downloads
Put in the wiring loom, put the grommets in the bulk head, and glued the foam to the bulk head.
Attached File  PXL_20220404_175913794.jpg   84.78K   1 downloads
Put the drive shafts in.
Attached File  PXL_20220404_175934521.jpg   68.26K   1 downloads
Installed the cylinder head last night.
Attached File  PXL_20220405_205554007 (1).jpg   96.08K   2 downloads
