All of the suspension components, barring the rear trumpets, rear hubs (need a puller), and front upper arms have now been fully stripped ready for shot blasting and powder coating
PXL_20211221_145158034 (FILEminimizer).jpg 64.24K
1 downloads
I decided that it would also be prudent to split the brake callipers and refurbish them properly. I've come this far, no point stopping now.
PXL_20211221_145207743 (FILEminimizer).jpg 56.05K
1 downloads
Definitely going to require some new backplates.
The front bearings, are also going to be changed. So I've removed these from both stub axles. I did however note that on one side, the circlip was missing. Not sure what the end result of this could be, but I'd rather not find out.
PXL_20211221_133425504 (FILEminimizer).jpg 36.25K
0 downloads
Stripping down the front stub axle with an air impact wrench was a revelation. I had one or two bolts that were stuck, but hammering on an impact socket and using the impact wrench on them again was pretty much a doddle compared to what I've had to do before to remove stubborn/rounded bolts..
The rear trumpets have the remnants of the metal insert from the donut stuck to them and I'm struggling to remove the shock absorber pin from the front upper arms. I'll have to wait until after christmas to sort these as I'm not allowed to use my new blow torch, christmas present, until after then.
After being off the road since 2017, and starting this restore, I think I'm starting to see the light at the end of the tunnel. Still a way to go, but at least now I'm not far off the point whereby I'm just bolting parts on the car, which I'm much more familiar with!
Edited by Mito, 21 December 2021 - 04:57 PM.
