The Red One
137 replies to this topic
#61 Mito
Mito
  • 407 posts
Posted 24 January 2021 - 10:30 PM
I've got a few updates to put on but I haven't found a good/easy way to compress the photos so that they can be uploaded to this site.
I managed to get the boot floor to meet up to the rear arch much better than in the last pics. Clamping the floor to the rear quarter took up most of the gap. I think it also took a bit of hammering and reshaping of the bottom of the rear arch to close the gap up a bit. The inside rear corner of the arch where it meets the boot floor was also holding the floor off and had to be reshaped slightly. Once I got it close enough, I then put a seam weld across the rear bottom edge of the arch and the boot floor and plug welded the rear quarter lip to the boot floor.
The better way to close the gap with the rear valance and the closing plate would be to fabricate a small piece to take it up to the edge of the valance. I on the other hand, filled it with weld and then ground it back, rather effective I thought but using a piece of sheet metal would have been soo much easier.
#62 Jamez26
Jamez26
  • 487 posts
Posted 30 January 2021 - 08:16 PM
Thanks for the info Mito and look forward to your updates
#63 Mito
Mito
  • 407 posts
Posted 01 May 2021 - 05:55 AM
Frontend welded.
Attached File  IMG_20200426_150522 (FILEminimizer).jpg   60.9K   4 downloads
Attached File  IMG_20200615_155029.jpg   50.2K   7 downloads
Lining up the a-panels with the doors.
Attached File  IMG_20200519_163931 (FILEminimizer).jpg   33.49K   3 downloads
Attached File  IMG_20200522_115059 (FILEminimizer).jpg   37.85K   2 downloads
Grinding back some of the welds at the rear end.
Attached File  IMG_20200502_201159 (FILEminimizer).jpg   35.75K   3 downloads
Put a seam weld along the heal board to closing plate.
Attached File  IMG_20200504_145310 (FILEminimizer).jpg   53K   3 downloads
Tidying up welds around the wheel arch.
Attached File  IMG_20200504_145315 (FILEminimizer).jpg   47.29K   4 downloads
Plug welding the bottom of the wheel arch to boot floor.
Attached File  IMG_20200511_153323 (FILEminimizer).jpg   63.43K   1 downloads
Put in a little patch where the metal had got a bit thin due to rust.
Attached File  IMG_20200522_164404 (FILEminimizer).jpg   34.67K   1 downloads
Welding in the repair panel on the o/s rear quarter.
Attached File  IMG_20200522_164411 (FILEminimizer).jpg   35.44K   1 downloads
Starting repairing the doors. Took the skin off. Bit of a mess around the edges. The rust was all cut out.
Attached File  IMG_20200701_174522 (FILEminimizer).jpg   63.36K   1 downloads
New metal being welded in.
Attached File  IMG_20200703_173409 (FILEminimizer).jpg   67.5K   2 downloads
Epoxy primed the inside of the doors and the new skins.
Attached File  IMG_20200820_114431 (FILEminimizer).jpg   51.79K   2 downloads
Attached File  IMG_20200820_114446 (FILEminimizer).jpg   31.6K   4 downloads
Lined up the doors.
Attached File  IMG_20201017_175807 (FILEminimizer).jpg   44.62K   4 downloads
Starting to prep for painting.
Attached File  IMG_20201109_170459 (FILEminimizer).jpg   54.07K   3 downloads
The paint prep is now finished but haven't taken any photos yet. I'll take some today before the primer starts going on :)
#64 johnR
johnR
  • 2,289 posts
Posted 01 May 2021 - 11:07 AM
You're getting closer to the finishline of your epic marathon- well done. have you been restoring the parts to bolt back on as you go or leaving those 'til the shell is finished?
#65 Mito
Mito
  • 407 posts
Posted 01 May 2021 - 04:36 PM
I've had the front subframe shot blasted and powder coated and have binned the rear subframe as it was too far gone, so will be buying a new one.
I've been stripping the other parts down when I've not been able to work on the shell and pretty much have to just treat the rust on them and repaint before re-assembly. The bearings for the front top arms are proving to be a pita to remove though. I've also been looking at may be buying a bench shot blasting cabinet to remove the rust as they don't appear to be too expensive and will make it easier to clean up the parts.
#66 colinf1
colinf1
  • 989 posts
Posted 01 May 2021 - 06:58 PM
If you don't have the bearing removal tool, this chap shows how to do it with a ground down washer.
https://youtu.be/0U83AVdEz2o
#67 Maccmike8
Maccmike8
  • 1,101 posts
Posted 01 May 2021 - 08:25 PM
Wonderful idea.
#68 Mito
Mito
  • 407 posts
Posted 02 May 2021 - 07:56 AM
I'll give that a go!
#69 Mito
Mito
  • 407 posts
Posted 10 May 2021 - 08:24 AM
Masked up some of the car ready for priming underneath.
Attached File  PXL_20210502_095615015 (FILEminimizer).jpg   68.13K   1 downloads
Attached File  PXL_20210502_095625638 (FILEminimizer).jpg   58.45K   2 downloads
Underneath is now in primer. The first attempt was a bit of a disaster with sags in the paint everywhere (no photos!). I put this down to a combination of poor gun set up and poor technique.
The second attempt went much better. I got a couple of sags on the boot where I was trying to get the gun/paint in behind the wheel well and rear valance. Other than that though, it went much better and it's now the underneath is primed and seam sealed.
Saggy!
Attached File  PXL_20210510_080230706 (FILEminimizer).jpg   38.81K   2 downloads
Attached File  PXL_20210510_080225892 (FILEminimizer).jpg   39.62K   2 downloads
Attached File  PXL_20210510_080217173 (FILEminimizer).jpg   44.98K   1 downloads
A bit of flatting and keying and ready for stone chip and top coat.
Edited by Mito, 10 May 2021 - 08:25 AM.
#70 Mito
Mito
  • 407 posts
Posted 10 May 2021 - 08:33 PM
Today I painted the underneath. It seems to have gone fairly well. Not a run in sight!
Attached File  PXL_20210510_193141604 (FILEminimizer).jpg   57.34K   8 downloads
Attached File  PXL_20210510_192953217 (FILEminimizer).jpg   54K   9 downloads
Attached File  PXL_20210510_192920215.NIGHT (FILEminimizer).jpg   61.1K   9 downloads
#71 Mito
Mito
  • 407 posts
Posted 27 June 2021 - 07:59 AM
After painting the underneath, the car was left on the spit for a couple of weeks to allow the paint to harden.
The car has now been taken off of the spit and is sat on axle stands and wooden battens.
After a couple of more weekends cleaning the car down, hoovered more times than it ever was when it was on the road and panel wiped, the car was ready for some epoxy primer.
Attached File  PXL_20210627_073100815 (FILEminimizer).jpg   57K   6 downloads
Attached File  PXL_20210627_073118527 (FILEminimizer).jpg   50.59K   4 downloads
Attached File  PXL_20210627_073125615 (FILEminimizer).jpg   48.7K   3 downloads
Attached File  PXL_20210627_073140087 (FILEminimizer).jpg   64.17K   2 downloads
There are a few sags in places, that I will sand out - still haven't find the right technique for this, the car is now fully epoxy primed.
#72 Mito
Mito
  • 407 posts
Posted 27 June 2021 - 08:03 AM
Almost forgot, before priming, I drilled the holes for the wheel arches and the works lamp bar.
Attached File  PXL_20210620_153838045 (FILEminimizer).jpg   73.47K   5 downloads
#73 Mito
Mito
  • 407 posts
Posted 29 July 2021 - 08:07 PM
I was struggling to reach the roof properly when spraying it, I'm not the tallest, so bought a work platform from Screwfix. Then got on with spraying some high build primer on all the of visible sections, outside, inside of the doors, A & B pillars, cross member, dash rails, and the rear bins.
Attached File  PXL_20210726_200759468 (FILEminimizer).jpg   57.05K   0 downloads
Attached File  PXL_20210726_200806808.jpg   51.87K   2 downloads
Attached File  PXL_20210726_200817269 (FILEminimizer).jpg   56.08K   1 downloads
Attached File  PXL_20210726_200822407 (FILEminimizer).jpg   63.33K   1 downloads
Attached File  PXL_20210726_200824535 (FILEminimizer).jpg   58.25K   1 downloads
Next job will be to put some stone chip on the outside of the toe board and the rear arches, then some colour in the engine bay, boot, and rear arches of course.
#74 Mito
Mito
  • 407 posts
Posted 02 August 2021 - 04:27 PM
Today, I got on with spraying the boot, engine bay, and both rear arches.
Engine bay all nice and shiny red...
Attached File  PXL_20210802_144250479 (FILEminimizer).jpg   60.68K   5 downloads
Some runs, but they'll buff out  :shifty:
One of the rear arches, all stone chipped and shiny red...
Attached File  PXL_20210802_144119212 (FILEminimizer).jpg   52.54K   3 downloads
The boot all shiny red...
Attached File  PXL_20210802_144135051 (FILEminimizer).jpg   32.06K   3 downloads
A closer look at the shiny red boot...
Attached File  PXL_20210802_144205857 (FILEminimizer).jpg   30.05K   2 downloads
The offside of the boot...
Attached File  PXL_20210802_144212480 (FILEminimizer).jpg   39.35K   1 downloads
The near side of the boot...
Attached File  PXL_20210802_144236547 (FILEminimizer).jpg   29.81K   0 downloads
Happy with that.
Next weekends job, or possibly the weekend after - stag do getting in the way, will be sanding down and spraying the inside of the car.
#75 Mito
Mito
  • 407 posts
Posted 03 October 2021 - 07:35 PM
The inside of the car is now sprayed.
Attached File  Photo Resizer 2021_10_03_08_15_13.jpg   43.59K   0 downloads
Attached File  Photo Resizer 2021_10_03_08_15_01.jpg   50.23K   1 downloads
Then, after a lot of sanding, I gave the areas where I had burned through a quick coat of epoxy mastic and then another couple of coats of high build primer.
Attached File  Photo Resizer 2021_10_03_08_14_41.jpg   68.94K   1 downloads
Attached File  Photo Resizer 2021_10_03_08_14_24.jpg   64.59K   1 downloads
Attached File  Photo Resizer 2021_10_03_08_14_04.jpg   65.61K   2 downloads
Attached File  Photo Resizer 2021_10_03_08_13_22.jpg   71.38K   2 downloads
Got a few runs in the primer and paint, so the next job is to sand down the primer and sand out the runs in the paint. Once this is done, I'll then give the inside another coat before moving onto the outside.
Getting there!
