The Red One
#46
Posted 10 March 2019 - 02:37 PM
The first oversill to come of doesn't look too bad.
IMG_20190309_155001.jpg 39.8K 2 downloads
The cross member and inner sill have seen better days and I'm not sure using sound deadening to cover the hole in the bottom of the rear bin is the correct way to repair the hole.
IMG_20190309_155047.jpg 46.47K 2 downloads
IMG_20190309_155034.jpg 47.85K 1 downloads
IMG_20190309_155017.jpg 39.23K 0 downloads
Here's the main section of the floor I cut out.
IMG_20190310_114330.jpg 48.21K 1 downloads
The front part of the cross member is no longer attached to the floor!
IMG_20190310_114338.jpg 53.06K 0 downloads
This part just folded over without any cutting!
IMG_20190310_114344.jpg 48.22K 0 downloads
I've just got this bit too grind back before I can start derusting and lining up the new floor.
IMG_20190310_141738.jpg 48.47K 0 downloads
And I'm very glad I didn't decide to just repair the bits it failed on after the horrendous not failure last year.
#47
Posted 02 January 2020 - 05:56 PM
It's been a while since my last update...
Things have progressed quite a bit since then and I can now see the end in sight, at least for the welding.
The floor has been prepped ready for welding...
IMG_20190312_203044.jpg 48.28K 0 downloads
Lining the floor up...
IMG_20190316_122429.jpg 43.26K 0 downloads
IMG_20190316_134846.jpg 32.77K 0 downloads
IMG_20190316_134917.jpg 33.97K 0 downloads
IMG_20190316_135009.jpg 32.42K 0 downloads
IMG_20190316_135017.jpg 32.03K 0 downloads
IMG_20190406_133630.jpg 70.99K 0 downloads
All looks good to me. I don't think I could get it to line up any better than that, so after a while decided to bite the bullet and get on with welding it to the rear seat and a couple of tacks on the door steps to hold it all in place.
The toe board was looking a bit rusty, so it had to go.
Adding some more bracing to keep the front end in line.
IMG_20190406_133621.jpg 80.42K 0 downloads
Then cut the old toe board out and used the front subframe to keep things lined up.
IMG_20190407_171858.jpg 47.3K 0 downloads
Lining up the new toe board...
IMG_20190407_171824.jpg 36.92K 0 downloads
IMG_20190407_171836.jpg 26.8K 0 downloads
IMG_20190407_171846.jpg 25.72K 0 downloads
Enough lining it up, on with welding it in...
IMG_20190420_172309.jpg 41.53K 0 downloads
This should hold it.
IMG_20190420_172604.jpg 74.74K 0 downloads
IMG_20190420_172611.jpg 74.89K 0 downloads
IMG_20190420_172651.jpg 49.5K 1 downloads
Then cut out out and replaced the corners of the panel it attaches too. I also had a go at a little panel beating as the new toe board is for a later model and didn't line up correctly with the original panel.
IMG_20190506_175313.jpg 39.29K 0 downloads
And then the other corner...
IMG_20190506_175320.jpg 40.45K 0 downloads
All done...
IMG_20190506_175329.jpg 40.78K 0 downloads
The cat payed a visit...
IMG_20190522_162030.jpg 77.42K 0 downloads
I've also been working on both sides of the rear end.. pics to follow shortly.
#48
Posted 02 January 2020 - 06:41 PM
On with the drivers side rear quarter. At this point, I had already welded in the closing plate, sill strengthener, rear arch, and the rear bin. I got a bit carried away and forgot to take photos until it was pretty much done.
Lining up the rear quarter was a bit of a pia but with a bit of persuasion managed to get it lined up reasonably well.
IMG_20190523_172512.jpg 50.02K 0 downloads
IMG_20190523_172639.jpg 62.75K 0 downloads
IMG_20190523_172619.jpg 30.55K 0 downloads
IMG_20190523_172528.jpg 63.79K 0 downloads
IMG_20190523_172603.jpg 75.26K 0 downloads
IMG_20190523_172521.jpg 24.25K 0 downloads
Unfortunately, it wasn't ready for the 2019 London to Brighton run, so I had to take the morbidly obese mini instead.
IMG_20190519_164556.jpg 55.81K 1 downloads
The shame!
cersei.jpg 6.44K 3 downloads
However, it came fitted with a tow bar and can tow just enough to be useful for moving it's older siblings around if need be.
On with the car. With the rear quarter panel now fitting pretty well, I decided to give my new spray equipment a try out. I bought an Apollo 1500 HVLP set up.
IMG_20191006_142046.jpg 57.35K 6 downloads
IMG_20191006_142101.jpg 43.29K 6 downloads
IMG_20191006_142144.jpg 63.04K 6 downloads
Once the paint (jotamastic primer) had the right viscosity it worked pretty well and was my first go at spraying with anything other than tins. There also wasn't any real over-spray, though this could be because I only sprayed a very small area.
On with the welding...
IMG_20200102_152636.jpg 45.46K 4 downloads
IMG_20200102_152641.jpg 40.33K 2 downloads
IMG_20200102_152647.jpg 51.96K 2 downloads
IMG_20200102_152654.jpg 33.61K 1 downloads
#49
Posted 02 January 2020 - 07:13 PM
Over Christmas and new year I've made a start on welding up the nearside rear corner.
The closing plate, rear bin, and sill strengthener have all been welded in.
IMG_20200102_152558.jpg 41.62K 3 downloads
IMG_20200102_152604.jpg 39.29K 3 downloads
IMG_20200102_152720.jpg 44.87K 2 downloads
IMG_20200102_152615.jpg 48.56K 5 downloads
Weld penetration in the rear arch.
IMG_20200102_152623.jpg 30.3K 1 downloads
Started welding in the repair panel.
IMG_20200102_172205.jpg 45K 3 downloads
The second of the two door steps has also been welded up, ready for grinding back.
IMG_20200102_152659.jpg 47.98K 4 downloads
Edited by Mito, 02 January 2020 - 07:19 PM.
#50
Posted 03 January 2020 - 05:47 AM
#51
Posted 03 January 2020 - 05:12 PM
Nice job coming together ?
The end is in sight now for the welding!
Today's progress...
I continued welding the offside rear arch to the rear quarter and the welding of the repair panel. I'm taking it slow though to avoid warping the panel.
IMG_20200103_163027.jpg 45.21K 0 downloads
IMG_20200103_163035.jpg 52.53K 2 downloads
Now it's a bit more solid, I decided to start cutting off the back panel whilst I waited for it to cool down
IMG_20200103_162117.jpg 75.53K 3 downloads
IMG_20200103_162845.jpg 64.91K 1 downloads
IMG_20200103_162145.jpg 52.81K 0 downloads
I'm really liking my new air nibbler.
I've just got the seams to grind back now so that I can line up the new panel and mark the position of the new panel for final cutting. I'm hoping that at this rate the back end will be mostly finished by the end of Sunday. I've got a few bits of rust on the drip rail which may require attention that I need to look at before I can declare the back-end complete from a welding perspective.
#52
Posted 04 January 2020 - 07:14 PM
I made a bit more progress on the back-end today.
I started by finishing off cutting off the back panel.
IMG_20200104_151148.jpg 76.42K 0 downloads
Which then allowed better access for welding of the two brackets between the wheel arch and boot floor.
IMG_20200104_165504.jpg 69.96K 0 downloads
IMG_20200104_185737.jpg 27.27K 0 downloads
I then made a couple of repair pieces for both corners of the rear seat back.
IMG_20200104_151214.jpg 84.41K 0 downloads
IMG_20200104_185717.jpg 32.38K 0 downloads
IMG_20200104_185659.jpg 53.92K 0 downloads
I'll get these welded in tomorrow.
Then I welded the rear seat belt anchor to the boot floor.
IMG_20200104_165456.jpg 59.39K 0 downloads
Oh, and there's now a hole in my airline where a bit of weld caught it
#53
Posted 05 January 2020 - 05:22 PM
Continuing on with the welding in the boot...
Decided to put some deox gel on the rear parcel shelf seam and also the rear quarter seam.
IMG_20200105_165820.jpg 73.05K 0 downloads
Put another couple of seam welds on the rear seat belt bracket.
IMG_20200105_165525.jpg 74.1K 0 downloads
Finished the welding of the rear arch brackets - little bead on the inside flange.
IMG_20200105_165515.jpg 85.86K 0 downloads
IMG_20200105_165506.jpg 69.46K 0 downloads
Welded in the repair pieces at the corners of the rear seat and welded up the rear seat belt brackets in the corners.
IMG_20200105_165501.jpg 77.33K 0 downloads
IMG_20200105_165449.jpg 81.7K 1 downloads
Looks to be getting good weld penetration.
IMG_20200105_165717.jpg 51.58K 0 downloads
IMG_20200105_165613.jpg 65.24K 0 downloads
Edited by Mito, 05 January 2020 - 05:37 PM.
#54
Posted 17 January 2020 - 06:03 PM
I made a bite more progress today lining up the rear panel and tacked it on in a few places.
IMG_20200117_171751.jpg 78.76K 2 downloads
IMG_20200117_171803.jpg 72.69K 0 downloads
IMG_20200117_171706.jpg 61.85K 0 downloads
IMG_20200117_171653.jpg 63.64K 0 downloads
I think it has lined up pretty well without too much adjustment.
I haven't lined up the seam at the bottom just yet and I think it will pull into place with a bit of effort. It's a bit awkward trying to pull it out and clamp it at the same time though.
IMG_20200117_171828.jpg 38.32K 0 downloads
#55
Posted 17 January 2020 - 07:19 PM
This is a huge undertaking! How much of the original shell will be left once you are done?
#56
Posted 17 January 2020 - 09:38 PM
#57
Posted 21 January 2020 - 09:01 PM
I continued with the welding on the back end
IMG_20200120_170741.jpg 30.19K 1 downloads
IMG_20200120_170719.jpg 40.53K 1 downloads
IMG_20200120_170712.jpg 36.48K 1 downloads
Lined up some of the front end panels
IMG_20200120_170820.jpg 44.49K 1 downloads
IMG_20200120_170758.jpg 40.84K 1 downloads
Stripped down the front subframe
IMG_20200119_173918.jpg 61.87K 1 downloads
IMG_20200119_173909.jpg 58.15K 1 downloads
IMG_20200119_173856.jpg 55.88K 1 downloads
IMG_20200119_173842.jpg 66.93K 1 downloads
I think it's salvageable so will send it in for blasting and powder coating
I've ordered a new bracket for the clutch master cylinder ready for replacing this...
IMG_20200119_173734.jpg 54.92K 0 downloads
I'm not sure if these need replacing yet either. I wonder what lurks beneath...
IMG_20200119_173722.jpg 54.89K 1 downloads
IMG_20200119_173711.jpg 64.28K 1 downloads
#58
Posted 15 February 2020 - 05:06 PM
I've been mostly working on lining up the rear valance and preparing it for welding over the last few days. I primed the rear of the valance and the closing plates with some jotamastic primer before I welded it on.
Here it is welded to the rear end.
IMG_20200215_163953.jpg 68.36K 2 downloads
IMG_20200215_164234.jpg 58.18K 3 downloads
I've blown through on one of the plug welds so I'll have to sort this out.
IMG_20200215_164321.jpg 85.94K 1 downloads
IMG_20200215_164345.jpg 94.21K 1 downloads
I think the rest of the welds have gone pretty well. The weld penetration from the underside of the boot lip.
IMG_20200215_164306.jpg 33.44K 1 downloads
The side bit of the closing plate still needs welding to the valance and the boot floor but I cant get at it at the moment due to the subframe being in the way, so I'll need to get this bit later.
I then started de-rusting the front bulkhead.
IMG_20200215_163757.jpg 81.27K 2 downloads
There's a bit of pitting in both corners of the cross member. This doesn't appear too bad though, so hopefully it will be okay after some deox gel has been applied.
IMG_20200215_163837.jpg 40.24K 1 downloads
IMG_20200215_163805.jpg 37.27K 1 downloads
I bought replacement panels for these but I don't think they are bad as I thought they were when the paint was still on, so I think I'll keep these as is and just de-rust them.
IMG_20200215_163814.jpg 66.73K 1 downloads
IMG_20200215_163907.jpg 63.36K 0 downloads
I'm going to cut off the rear engine steady bracket as it looks like there is some nastiness going on behind it.
The bonnet brackets look okay but there is some surface rust. Not sure what to do here as I dont really want to cut them off but also want to get at the surface rust.
IMG_20200215_163857.jpg 63.31K 1 downloads
IMG_20200215_163848.jpg 87.2K 1 downloads
Edited by Mito, 15 February 2020 - 05:09 PM.
#59
Posted 25 April 2020 - 05:20 PM
I decided to take off the bonnet hinge brackets following the advice from members on this forum and I probably knew I should deep down.
I've also put on both inner wings, the scuttle, and have just lined up the front end today ready for welding on. I think i've had the front end on and off about 5 times now just trying to get it lined up and it's now as right as i'm going to get it. The panel gaps all loom about right but there is a slight issue with the drivers side wing which is being pushed out when I put the a-panel in. I think the a panel seam just wants a bit of work to move it back a little bit so that it doesn't push the wing out.
Here are some of the pics.
Posted 24 January 2021 - 09:35 PM
Hi mate, Great progress, really enjoyed looking through your thread. Any more updates ?
Could I ask you a couple questions, see where your boot floor meets the rear arch and the rear arch corner, there is a small gap ? I also have this on my current project, I'm wondering how you go about finishing this off? And also the same for where the outer corner of your arch closers meet the valance, theres a small gap at the top, did you close these off ?
Cheers, James
