The Red One
137 replies to this topic
#16 Mito
Mito
  • 416 posts
Posted 30 March 2018 - 10:10 AM
The rear end of the boot has been cut out and a repair panel welded in place. I learnt from the last time I did this and cut out as little of the wheel well as possible, as the repair panel really doesn't line up too well.
Attached File  WP_20180322_15_38_25_Pro.jpg   28.84K   1 downloads
Attached File  WP_20180322_15_38_31_Pro.jpg   34.85K   2 downloads
Attached File  WP_20180323_19_07_13_Pro.jpg   34.27K   1 downloads
Attached File  WP_20180323_19_07_23_Pro.jpg   24.31K   1 downloads
Attached File  WP_20180323_19_07_33_Pro.jpg   35.26K   3 downloads
Attached File  WP_20180323_19_07_46_Pro.jpg   60.17K   2 downloads
There were a couple of big gaps remaining after the repair section had been lined up and welded in, so I added in a couple of pieces of metal to fill in the holes.
Attached File  WP_20180326_15_34_26_Pro.jpg   45.55K   2 downloads
Attached File  WP_20180326_15_35_02_Pro.jpg   26.68K   0 downloads
I then reattached the rear subframe to the car to mark the holes for the rear subframe mounts and then drilled the new panel.
Attached File  WP_20180326_15_35_40_Pro.jpg   62.45K   2 downloads
After applying some weld through primer to the underneath, I then got started cutting out what remains of the left hand inner wing.
Attached File  WP_20180329_18_16_16_Pro.jpg   53.23K   1 downloads
#17 Mito
Mito
  • 416 posts
Posted 30 March 2018 - 11:11 AM
Cat inspection
Attached File  1522408251779-191384206.jpg   85.4K   1 downloads
#18 blueovalcraig
blueovalcraig
  • 193 posts
Posted 30 March 2018 - 11:44 AM
Great work.
#19 Mito
Mito
  • 416 posts
Posted 30 March 2018 - 12:34 PM
Loosely fitted the inner wing.
Attached File  1522413199439-1223003363.jpg   104.22K   3 downloads
#20 Mito
Mito
  • 416 posts
Posted 30 June 2018 - 01:28 PM
Carried on some welding on the rear corner.
And then started grinding back...
Oops!
#21 Mito
Mito
  • 416 posts
Posted 21 October 2018 - 01:04 PM
Starting to replace the nearside rear arch.
Attached File  IMG_20181021_135716.jpg   76.65K   1 downloads
I've been grinding the spot welds off rather than drilling them out as I find it easier. I kept seeing smoke being given off from the old seam sealer behind so decided to remove it rather than risk a fire.
I wish I'd done this before I'd welded in the rear repair panel as there are holes and rust everywhere!
Attached File  IMG_20181021_135656.jpg   45.79K   1 downloads
So, fine you can have a new boot floor as well!
Edited by Mito, 21 October 2018 - 01:06 PM.
#22 Mito
Mito
  • 416 posts
Posted 21 October 2018 - 04:27 PM
I've not got the old arch out and just need to tidy up the rear seat panel a little before welding in the new arch.
New arch offered up. It doesn't seem to be too far out.
Attached File  IMG_20181021_172048.jpg   61.6K   5 downloads
The old arch with holes and old patch repair at the front.Attached File  IMG_20181021_172148.jpg   43.92K   4 downloadsAttached File  IMG_20181021_172212.jpg   85.99K   1 downloads
#23 Mito
Mito
  • 416 posts
Posted 10 November 2018 - 02:54 PM
Bought a new toy. A sealey metal hole punch.
Attached File  15418615228391122107296.jpg   103.45K   2 downloads
It's much quicker than drilling all of the holes for plug welding and it makes quite a nice hole.
Attached File  15418615901961592190082.jpg   76.65K   1 downloads
So good so far.
Edited by Mito, 10 November 2018 - 02:54 PM.
#24 Mito
Mito
  • 416 posts
Posted 10 November 2018 - 05:51 PM
Theres only the odd bit of surface rust left so Detox gel applied to all the seams which I'll leave overnight to do its thing.
Attached File  15418721483732128152690.jpg   68.06K   0 downloads
Almost ready to start welding the new wheel arch in.?
#25 Mito
Mito
  • 416 posts
Posted 11 November 2018 - 07:04 PM
Today I cleaned out the deox gel and zinc primed. It's now ready for welding but as I'm having to wait for paint to dry I decide to crack on with cutting out the other wheel arch.
I waved the grinder near to the seam with the rear quarter panel and it quickly became clear that the only part still connected to the car was the front quarter. The rest had completely rusted away!
It's almost out now but there's a seam weld behind the rear seat panel which has been put the as part of a bodged repair. The patch at the other side was three layers thick and the tac welds hadn't penetrated so it pretty much pulled off with a small amount of leverage
Attached File  IMG_20181111_170624.jpg   40.52K   2 downloads
#26 jomaoliveira79
jomaoliveira79
  • 64 posts
Posted 12 November 2018 - 12:31 AM
Very rusty shell for it's age, many people would just simply scrap it. Very glad to see you are boldly saving this car.
Keep up the good work!
#27 Mito
Mito
  • 416 posts
Posted 17 November 2018 - 04:05 PM
I started today removing the offside wheel arch out.
Not much remains and there were a number of previous patch repairs which made taking this side out more difficult than the other side.
Here's the remains...
Attached File  IMG_20181117_155946.jpg   83.38K   1 downloads
Attached File  IMG_20181117_160017.jpg   48.18K   1 downloads
Attached File  IMG_20181117_160054.jpg   33.46K   1 downloads
#28 johnR
johnR
  • 2,302 posts
Posted 17 November 2018 - 09:01 PM
When you said you wanted it finished by May you failed to mention which year?!!
#29 Mito
Mito
  • 416 posts
Posted 17 November 2018 - 09:09 PM
Yeah, I think that was deliberate! Lol
#30 Jamez26
Jamez26
  • 487 posts
Posted 22 November 2018 - 10:23 PM
That's some set of arches  >_< , good luck with the build. looking good so far.  Doing similar work on my own at the rear at the moment.
