The Red One
137 replies to this topic
#1 Mito
Mito
  • 407 posts
Posted 26 March 2017 - 11:56 AM
Thought I'd better start a project thread for my red one. It's a 998 1991 rover mini. It started life as a studio 2 and at some point, fairly recently, was very roughly resprayed in red. I'll be doing it as a rolling restoration up until i get to replacing the floor and I'll hopefully have the blue one on the road by then. Just reminded myself of the old milky way advert!:-)
Attached File  WP_20170326_12_53_34_Pro.jpg   66.94K   23 downloadsAttached File  WP_20170326_12_54_02_Pro.jpg   60.46K   18 downloadsAttached File  WP_20170326_12_54_23_Pro.jpg   72.97K   14 downloadsAttached File  WP_20170326_12_54_55_Pro.jpg   58.29K   17 downloads
Edited by Mito, 26 March 2017 - 01:27 PM.
#2 Cameron2310
Cameron2310
  • 10 posts
Posted 26 March 2017 - 12:12 PM
x
Edited by Cameron2310, 11 July 2021 - 10:58 PM.
#3 Mito
Mito
  • 407 posts
Posted 26 March 2017 - 01:03 PM
It will take a bit longer than I'd hoped but will just repair a bit at a time. So long as it's back on the road for the end of may, I'll be happy
Attached File  WP_20170326_14_01_14_Pro.jpg   89.13K   15 downloadsAttached File  WP_20170326_14_01_22_Pro.jpg   61.61K   7 downloadsAttached File  WP_20170326_14_01_19_Pro.jpg   71.69K   6 downloads
Edited by Mito, 26 March 2017 - 01:13 PM.
#4 Mito
Mito
  • 407 posts
Posted 26 March 2017 - 06:48 PM
The rebuilding begins...
Attached File  WP_20170326_19_48_12_Pro.jpg   36.03K   13 downloads
Doesn't look like the door strengthener is quite right???
Attached File  WP_20170326_19_47_43_Pro.jpg   37.68K   11 downloads
Edited by Mito, 26 March 2017 - 07:15 PM.
#5 Mito
Mito
  • 407 posts
Posted 11 February 2018 - 02:19 PM
It looks like I forgot to update this thread after finishing off rebuilding the front flitch and a panels.So, heres a couple of after pics taken just before I started stripping down the car.
Drivers side all rebuilt.
Attached File  WP_20180211_11_58_58_Pro.jpg   30.03K   1 downloads
Passenger side rebuilt.
Attached File  WP_20180211_11_58_23_Pro.jpg   29.04K   2 downloads
Now the strip down begins.
Face off! There isn't much, if any, metal left underneath the headlights.
Attached File  WP_20180211_12_55_26_Pro.jpg   51.13K   5 downloads
Took the rear headlamp out and theres something wrong with the rear arch, I just can't quite put my finger on it ;)
Attached File  WP_20180211_13_42_44_Pro.jpg   56.84K   2 downloads
Attached File  WP_20180211_13_42_59_Pro.jpg   70.39K   2 downloads
I'm not sure about the bumper ?rail? but doesn't appear to look too bad around the bottom of the boot.
Attached File  WP_20180211_13_57_04_Pro.jpg   35.7K   2 downloads
Attached File  WP_20180211_13_57_10_Pro.jpg   33.25K   1 downloads
Attached File  WP_20180211_13_57_18_Pro.jpg   39.79K   1 downloads
I'm sure there will be some more horrors to come. To be continued...
#6 Mito
Mito
  • 407 posts
Posted 22 February 2018 - 07:57 PM
Tonight I've emptied the boot. It's now ready for the subframe to be dropped.
Holes are bigger than expected.
Attached File  WP_20180222_19_31_12_Pro.jpg   63.15K   1 downloads
Attached File  WP_20180222_19_31_18_Pro.jpg   55.28K   0 downloads
Attached File  WP_20180222_19_31_23_Pro.jpg   39.23K   0 downloads
I can see daylight through the rear arch.
Attached File  WP_20180222_19_31_31_Pro.jpg   57.96K   2 downloads
And there don't appear to be any holes in the battery box which shouldn't be there.
Attached File  WP_20180222_19_31_39_Pro.jpg   55.87K   2 downloads
#7 Mito
Mito
  • 407 posts
Posted 24 February 2018 - 07:25 PM
Carried on with stripping the car down today by taking the engine out.
The engine mount bolts were a right pita to get too!
Attached File  WP_20180224_19_05_36_Pro.jpg   51.75K   3 downloads
#8 Mito
Mito
  • 407 posts
Posted 04 March 2018 - 05:15 PM
Dropped the front sub frame and started cutting away the front panels to assess how many panels i'll be needing.
Both inner wings need work and possibly full replacement.
Attached File  WP_20180304_16_18_06_Pro.jpg   60.8K   0 downloadsAttached File  WP_20180304_16_18_17_Pro.jpg   48.49K   1 downloadsAttached File  WP_20180304_16_18_27_Pro.jpg   51.54K   1 downloadsAttached File  WP_20180304_16_25_06_Pro.jpg   56.07K   1 downloadsAttached File  WP_20180304_16_18_32_Pro.jpg   52.85K   2 downloadsAttached File  WP_20180304_16_18_42_Pro.jpg   55.84K   2 downloads
And surprisingly someone's filled over some rust in the boot.
Attached File  WP_20180304_16_24_24_Pro.jpg   45.99K   1 downloadsAttached File  WP_20180304_16_24_27_Pro.jpg   50.56K   0 downloads
#9 Mito
Mito
  • 407 posts
Posted 08 March 2018 - 08:39 PM
Took out the Windscreen, dashboard and top rail.
Attached File  WP_20180308_19_43_43_Pro.jpg   45.78K   3 downloads
#10 Mito
Mito
  • 407 posts
Posted 10 March 2018 - 07:34 PM
Removed all of the glass and doors today, plus another few bits and bobs.
Cut the front panel off as well.
Attached File  WP_20180310_14_54_09_Pro.jpg   32.98K   0 downloads
Attached File  WP_20180310_14_53_57_Pro.jpg   44.87K   0 downloads
And the bulk head cross member has quite a bit of rust on it. Heres hoping that it is only surface rust!
Attached File  WP_20180310_17_38_13_Pro.jpg   46.68K   0 downloads
Attached File  WP_20180310_17_38_26_Pro.jpg   49.7K   0 downloads
Attached File  WP_20180310_17_38_32_Pro.jpg   49.4K   0 downloads
Edited by Mito, 10 March 2018 - 09:19 PM.
#11 johnR
johnR
  • 2,289 posts
Posted 11 March 2018 - 04:25 PM
Quite a bit to do there - good luck with it
#12 Mito
Mito
  • 407 posts
Posted 17 March 2018 - 12:40 PM
Parts arrived!
Inner wings and pieces to go under the scuttle corners.
Attached File  WP_20180317_12_25_01_Pro.jpg   42.09K   1 downloads
Rear arch, boot repair panel, a panels and scuttle corners.
Attached File  WP_20180317_12_24_43_Pro.jpg   35.64K   2 downloads
Rear valance, closing plates, repair panels for boot and ?rear arch strengtheners. Not forgetting the petrol tank fixing bracket.
Attached File  WP_20180317_12_25_15_Pro.jpg   36.28K   1 downloads
There's a full floor assembly in the box
Attached File  WP_20180317_12_25_55_Pro.jpg   49.24K   0 downloads
Everything I need for now!
#13 Mito
Mito
  • 407 posts
Posted 17 March 2018 - 03:22 PM
I've not even waved the angle grinder near it yet!
Attached File  WP_20180317_15_18_30_Pro.jpg   52.12K   1 downloads
Attached File  WP_20180317_15_18_17_Pro.jpg   60.65K   1 downloadsAttached File  WP_20180317_15_18_26_Pro.jpg   50.24K   0 downloads
Edited by Mito, 17 March 2018 - 03:23 PM.
#14 Mito
Mito
  • 407 posts
Posted 22 March 2018 - 03:37 PM
​A "good solid repair" behind a good 2mm of filler with holes either side????
Attached File  WP_20180322_15_30_48_Pro.jpg   36.72K   7 downloads
#15 MacGyver
MacGyver
  • 1,027 posts
Posted 23 March 2018 - 08:13 AM
Good to see it properly tacked in... 😶
