Convert Mk3 Column Ignition To Mk1 Dash Ignition
3 replies to this topic
#1 slack
slack
  • 65 posts
Posted 23 March 2017 - 12:28 AM
Hello,
Can someone explain how can i convert the mk3 ignition to a mk1 dash ignition?
I know that i need a push button to start but my problem it's the mk3 ignition have 4 wires and the mk1 are only 3...
If someone knows how to do that please give me a tip.
Thank you
#2 mab01uk
mab01uk
  • 12,412 posts
Posted 23 March 2017 - 07:25 AM
Only early Mk1's had a floor start push button (up to approx Sep 1964)......the later Mk1's had a combined ignition/key start on the dash. So did the Mk2 and early Mk3......the column ign/starter with steering lock came in on Mk3's in late 1970/ early 71.
The dash mounted combined ignition and starter switch is not the same as the ignition switch used on early floor starter cars.
http://www.somerford...page=page&id=86
Edited by mab01uk, 23 March 2017 - 07:37 AM.
#3 slack
slack
  • 65 posts
Posted 23 March 2017 - 11:02 PM
I understand but i mean a push button like savage button and the dash barel ignition. It's possible to do something like that? I have a column ignition barel and i want to change a little
#4 Ethel
  • 25,919 posts
Posted 24 March 2017 - 01:22 AM
It may be a construction and use thing for your car to have the steering lock, I certainly can't see your insurers being happy about it being removed.
The barrel is just a 3 position switch with a common supply, if you didn't use the starter terminal (red/white) the accessory and ignition terminals will still work normally. The barrel does also provide the detents to keep the steering lock from locking. Expect to need a relay if you add a push start switch.
